Undutched
is European, stick together!
Rather lost: Oil Pump
Hello,
I am a bit lost on the oil pump issue. Currently I have a N1 Oil Pump installed (now about 2-3k miles). When buying it, I had no knowledge about the failure potential. The question, why and how do they fail? How difficult (for a shop) is the change of the oil pump? If the fitting does not require removal of engine or sump, I may look into buying one. Info: RB28 running GT-SS's Regards.
R.I.P.S NZ
is happy with a mild mannered 8.51 @ 163 in MGAWOT II
Cars owned: R32 GTS4
To change the oil pump requires removal of the sump and although "possible" to remove the sump in place, most agree its far easier to remove the engine and do it properly on an engine stand.
Good luck :-)
#4 (permalink) | |
TurboSE
is working on getting this motor back together for
summer.
Undutched
I think that'll be on the list for next year then if it needs removal. My personal redline is at around 7,500 due to the GT-SS running close to their peak power.
armt350
The gerotor gearing is made out of sintered metal. Because of the way sintered metal is formed it has a brittle property which is the weak point exploited by a higher reving engine and the vibrations that occur. This can and will occur even with a servicable harmonic balancer or even an aftermarket type that are available.
Also the early RB26's had the crank collar issue where the contact patch was too small causing that failure. The following occured with a ross balancer during a downshift from 3rd to 2nd. You can see how the gear broke. ![]()
#10 (permalink) | |
godzirra
herman
is i cant believe my 32 is gone im gutted.
wish id taken some pics of mine wene i replaced my origanal crank(short nosed)the contact area was stupidly minamal and at the time the garage was full and everyone said so surprised it was still in one piece
(lucky for me it still was).ive got a 33 crank in mine now with jun oil pump and harmonic balancer to.i was told alot of the time failours were down the high revving and vibrations.nice pic to show damage caused
#12 (permalink) |
armt350
This is a oem pump, although the N1 suffers from the same sintered material as the oem, only difference is the outside gear diameter is 4mm different, tooth style is the same. That pump was replaced by a N1 Housing and a reimax gerotor gearset and has been happily reving to 9500 rpm since
