JDMAutoLink
is online 24/7
Nismo 480cc Injectors (16600-RR710) - ER34
We have a set of like-new (6 pcs) of Nismo 480cc injectors (Part No. 16600-RR710) for the Nissan Skyline R34 GTT (ER34). These injectors were only installed for 20 hours on an ER34 at the tuning shop before it was swapped for higher cc ones.
These are plug and play into the stock fuel rail and offers additional fueling needs of boosted up engines. The Nismo 480cc injectors have 4 spray nozzles per injector instead of a single or dual spray nozzle one would usually find on aftermarket injectors. These top feed high impedance 4 hole spray pattern injector will produce very nice atomisation. Besides the ER34, it will also be compatible with CPV35, C35, Z33, WGC34 and WGNC34. GBP500 ![]() ![]() ![]() ![]() ![]() ![]()
JDM AUTO LINK Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Contact us: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. NITTO Performance Engineering To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Ecliptech SHiFT-i Progressive Shift Indicator. The ultimate shift light system - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. LED Taillights To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
JDMAutoLink
is online 24/7
Item sold!
