111mattin111
Rebuild
Hi everyone while having my rb25 rebuilt with new pistons, rods, oil pump, water pump bearings ect is there anything else you would recommend doing to the block whilst it's stripped, the aim is for around 500hp
What about having the oil journals done, de stressing the block, balanced ect? Thanks Paul
Marky_GTSt
is a Fire Engine
Cars owned: Skyline GTSt
Yea, Swap the core plugs
Is it just the block your wanting info on or will you be doing the head as well ?Are you building it or a tuner ?
I am Jacks complete lack of surprise. |
111mattin111
Going to get someone to build it don't know who yet leaving head standard apart from some mild cams so now just need to what people recommend on the block
What I don't want is some garage saying I need this and that doing when it's not really needed
Moops
is Niceeeeeeeee...
deburr and polish up the inside of the block, all the casting marks and casting flakes sitting around. You can easily do this yourself after you pull and strip the motor with a die grinder and some carbide burrs.
You could also remove all the plugs in the block/head and crank if you have a hand drill and some skill using it, its not very hard to do. As above, remove the core plugs too. The more you can do, the less things the machineshop have to do and charge out.
Moops
is Niceeeeeeeee...
Having a super clean area to assemble it all in and measuring everything accurately. That usually means having good tools and measuring equipment. Micrometers, dial bore gauges, dial indicator, vernier calipers and feeler gauges are the most common measuring tools you will use. Probably a good torque wrench and stretch gauge.
#7 (permalink) | |
TheD
is busily writing apps for the app store
Simonh
is back in a GTSt
Cars owned: R33 GTR-S
I would suggest doing everything to he head you think you would ever want to do while it is already off. A the very least do your valve stem seals.
#9 (permalink) | |
Moops
is Niceeeeeeeee...
You commonly use a carbide burr in your die grinder or a similiar tool to smooth out these casting imperfections.
