400gtr
is a skylineaphile
Fitting throttle sensor
Have to fit a new throttle sensor on r33 gtr, and was told by dave w that it has to be fitted the same way/angle as the one that has been removed. Which is the best way of doing this. I was thinking either making score marks around the edge of the 1 to be removed or either using tape to use as a outline around the top and bottom of it. I did a search and to no avail, if this a bit of a divy question sorry 1st problem I've had with the car in 3 years.
R32 Combat
is in limbo
Spannering again.
You could just fit it and hope for the best. Really, you need to measure the voltage and set it in the correct position.
SKYLAB FUSION. The 3rd generation torque split controller for the ultimate driving experience. This replaces your old G-Sensor for a digital, faster responding, unit along with offering the driver the ability to alter the balance of the cars 4WD power delivery for the optimum balance. A free fitting service is available at Skylab HQ, which is postcode RG19 Only £229. plus £10 p&p worldwide tracked postage Also available in the GTROC online shop To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
R32 Combat
is in limbo
Spannering again.
He's the man.
