#46 (permalink) |
Jimefam
Wow that is lighter than I thought. Great 1/8th time as well I'd be doing exceedingly well to run within 4 tenths of that in the S13. What are your 60' like?
#49 (permalink) |
GTR H
hey rips what fuel do you run ??? Also do you think youd be any quicker with a 2jz ??? just always wondered... Awesome acheivment watched the video wish i was there to see!!!
#50 (permalink) | |
R.I.P.S NZ
is happy with a mild mannered 8.51 @ 163 in MGAWOT II
Cars owned: R32 GTS4
I think for what it has (or more what it doesn't have), the engine in it is doing pretty well.
#51 (permalink) |
R.I.P.S NZ
RIPS FED 6.99 @ 192.7 mph worlds quickest and fastest RB part 1 - YouTube
RIPS FED 6.99 part 2: drive back after the 6 - YouTube
#52 (permalink) |
Jimefam
Awesome videos I specially enjoyed the drive back one I can imagine just how pumped you must have been definitely a great idea to drive it back.
#54 (permalink) | |
R.I.P.S NZ
![]() I'm not sure that a dragster is very aerodynamic, there's alot of open areas and restrictions where a full body can be made pretty smooth and "slippery" but without a wind tunnel we can't compare. How do you think project gtst would go on a 10.5 inch tyre and with a 2 speed transmission? Rob
#57 (permalink) | |
Lith
is lurking
What the run shows is the combination of its power delivery, chassis setup and madman behind the wheel are up to the task of doing a 6 at >190mph - the only other RB powered vehicles I know of trapping over 190mph was Heat Treatments at around 191mph, and HKS at around 193-194mph (in the 180SX). Some very very good company ![]()
#58 (permalink) | |
R.I.P.S NZ
The main thing I can't believe is the rpm it tollerates with the bottom end being stock other than the pistons and rods, who ever would have thought it would hold together at around 1500hp and 10,000rpm? not me thats for sure. We could EASILY build a much stronger bottom end, dry sump it, install a much better cylinder head, add a turbo in keeping with the size most guys would be running 6s with and make considerably more power but untill I blow the ass out of the motor I have I see no point, we struggle to use the power the motor makes now. The next goal is 6.7 to 6.8 @ 200mph with the same motor in the same spec with the same turbo, we just need to MAKE it rev to 10,500 wether it wants to or not, that will be done with less wing drag, more boost and more NOS if reqd and if that doesn't work we'll go to a slightly taller diff gear and load the motor more.
