Adamantium
is apparently indestructible!
Cars owned: GT-R & Audi Q5 3.0TDi Quattro S-Line Plus S-Tronic
Portable Hard Drive into USB
Hi all,
Just wondering if instead of using USB sticks I could put a higher capacity portable hard drive into the centre glove box? I ask because 32gb seems to be the max stick size and I have a bit more than that in terms of video files I'd like available. Has anyone done this? does it work and if so is there a size limit on the drive? Can you get solid state drives to do the same job? Thanks in advance from a non computer nerd. Adam
ChuckUK
is a proffesional loafer
Cars owned: MK3 VR6, Evo 6, Type-R, R32, GSI, VX220T, RRS-SC, RS4, GTR :)
I think as the format is Fat32 your limit is 32gb no matter what you connect.
briancgtr33
is going mad
i've got a 320gb hd pluged into my ps3 thats formatted to fatt32 the only problem is you can't play films bigger than 4gb.
I had problems the other day formating to fatt32 on windows 7 as it isn't there, but found a very good program that works great.. Ridgecrop Consultants Ltd
Adamantium
None of my films is even close to 4gb. They are all 350mb max low res 42 mins episodes of my favourite series from tv, dexter, the west wing, south park, family guy etc.
For all that, when I tried to play them this morning, again all I got was unplayable file. The file lists were there but despite being xvids, they did not play. I'd really appreciate a definitive explanation as to what will play on there.
Adamantium
I've played this same file type from this same stick before.
I used xilisoft to create the files and a 32gb stick.
#7 (permalink) | |
Blade
is Contemplating ridiculous mods
Cars owned: GTR MY11, Type R, E92 M3 sc, E60 M5, Z4 sc, M3 CSL, 360 Stradale, Integrale, 200sx, Evo 6 RSX, Tuscan, Griff 5.0, XKR, E39 M5..
Fat32 supports up to 8Tb partition sizes!
markpriorgts-t
is R33 GTR
Cars owned: R33 GTR
Been a while since i looked at FAT32 in depth but its no where near that
Table 3.11 FAT32 Size Limits Description Limit Maximum file size 2 32 - 1 bytes Maximum volume size 32 GB (This is due to the Windows 2000 format utility. The maximum volume size that Windows 98 can create is 127.53 GB). Files per volume Approximately 4 million Important Windows 2000 can format new FAT32 volumes up to 32 GB in size but can mount larger volumes (for example, up to 127.53 GB and 4,177,918 clusters from a volume formatted with the limits of Windows 98). It is possible to mount volumes that exceed these limits, but doing so has not been tested and is not recommended.
ChuckUK
I wasn't referring to the technical limitations rather the commonly excepted compatible size. 3rd party tools and OS recognition seems to warrant 32gb. Of course PS3 are sometimes the exception to the rule over NTFS.
Adamantium
So, with that out of the way, can I make something bigger than 32gb work in the gtr through the usb socket?
#11 (permalink) | |
ChuckUK
I don't have any 64gb or larger solid state devices like USB sticks to try. In the end I purchased a 160gb Ipod which works perfectly.
#12 (permalink) | |
Anders_R35
is Shells best customer
MY11 Daytona Blue - GTC Downpipes & Intakes, Whifbitz 4" exhaust, AMS FMIC, ASNU 1100cc Injectors, Ryan G map - 651bhp / 620lbft Alcon 400mm front discs, Alcon 380mm rear discs, Pagid RS29 pads, Castrol SRF Fluid, Carbon bonnet vents, Mines steering wheel |
#13 (permalink) |
Adamantium
Yep, what's your point?
Seriously, can someone tell me the exact video format I need, can't get it to work now.
#14 (permalink) |
ChuckUK
DivX works fine, or you can use the open source Xvid version but you need to change the fourCC of the files.
#15 (permalink) |
Adamantium
I've been using xvid. Divx is an option.
No idea what fourCC s.
