Wideband sensor - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Tuning: General
Notices
Old 13th May 2012, 07:45 PM   #1 (permalink)
Simonh is back in a GTSt
Simonh's Avatar
Cars owned: R33 GTR-S
Wideband sensor
Brought myself a Wideband lambda sensor, where is the best location to put it? I have a boss in the decat but not sure if that is too far back?
Old 14th May 2012, 07:05 PM   #2 (permalink)
gtr-loz is cold
gtr-loz's Avatar
That's where I fitted mine and it's been fine. Most tuners tune from the tailpipe just remember the further back the sensor it will show leaner than the engine actually is
gtr-loz is offline   Reply With Quote
Old 14th May 2012, 07:07 PM   #3 (permalink)
MIKEGTR is rolling on double deuces
MIKEGTR's Avatar
Cars owned: Midnight Purple R33 GTR, Range Rover Vogue
Most tuners also use a £3k wideband, I'm presuming this one isn't.
You don't have to agree with me, I can't force you to be right :D
MIKEGTR is online now   Reply With Quote
Old 14th May 2012, 07:26 PM   #4 (permalink)
ianp is loving the R34
ianp's Avatar
Cars owned: 99 R34 GTR
Send a message via MSN to ianp
Mine is in my decat aswell
ianp is offline   Reply With Quote
Old 14th May 2012, 08:37 PM   #5 (permalink)
Simonh's Avatar
Well actually........ No it is the Inovate sensor and gauge
Old 14th May 2012, 08:57 PM   #6 (permalink)
Marlon88 is GTR addicted!
Marlon88's Avatar
Cars owned: BCNR33 & BNR34
Send a message via MSN to Marlon88
On AEM wideband manual it says to install from 18 inch to 36 inch away from turbo outlet. Anything closer will be too hot for the sensor and will shorten its life.
Marlon88 is offline   Reply With Quote
Old 14th May 2012, 09:17 PM   #7 (permalink)
Simonh's Avatar
In that case the decat is fine
Old 14th May 2012, 09:33 PM   #8 (permalink)
T.F.S. is fully aware that they can edit their status
T.F.S.'s Avatar
Cars owned: 32 GTR
Decat is fine, my AEM reads exactly the same as the silly priced autronic one and also the same as the one they use on the dyno dynamics rollers near me...just has a bit of a delay when they put it in the tailpipe
T.F.S. is offline   Reply With Quote
Old 15th May 2012, 06:50 AM   #9 (permalink)
Mark@Abbey M/S is looking forward to racing on the circuits again soon
GTR Register Trader
Mark@Abbey M/S's Avatar
Cars owned: Skylines...
It wont read any different at the tail pipe as long as the sniffer is far enough in so the 5 wire lambda sensor can sniff the fresh air that can get sucked in around the edge of the exhaust at low gas speed. but it will read slower than a Wideband fitted in the de-cat or further forward; Any Low speed low throttle work requires the 5 wire sensor I feel to be in the decat or downpipe for accurate readings.
Wouldn't say you need to spend 3k wideband, our Dynapack uses 2 Motec PLM,s , I am sure the Dyno Dynamic rollers use some similar , but any 5 wire lambda will read pretty accurate.
Servicing/tuning all Skyline models since 1990
Ecutek/Cobb/Syvecs and Up Rev approved tuners
In house Dynapack dyno
Up to date diagnostics for all Nissan,s Consult 1/2/3
Laser 4 wheel alignment equipment
Corner weight scales for trackset up
Tuner of the fastest Rb26 powered car in Europe
Any information needed give us a ring or mail us
Old 15th May 2012, 08:08 AM   #10 (permalink)
Simonh's Avatar
well it should be here today so the only other question is which gauge to drop in order to fit it, I am thinking the voltmeter is the least important (other options being boost, oil temp, water temp and EGT)
Old 15th May 2012, 08:14 AM   #11 (permalink)
MIKEGTR's Avatar
IMO the two most important gauges are the air/fuel and the Egt, followed by oil pressure
Old 15th May 2012, 08:19 AM   #12 (permalink)
Simonh's Avatar
I think th emost important is the fuel gague - it is certainly the one that seems to move the fastest!
Old 15th May 2012, 08:30 AM   #13 (permalink)
MIKEGTR's Avatar
Lol I actually thought the same thing after I posted lol
Old 15th May 2012, 10:02 AM   #14 (permalink)
GTR Register Trader
AFR,EGT and Oil pressure and as the stock water temp senders are rubbish I would add a water temp gauge as well.
Old 15th May 2012, 12:05 PM   #15 (permalink)
Simonh's Avatar
well it arrived today - chuff me there is a lot to go with it, not sure where I will find space to put it all!
© 2001-2013 Cem Kocu
demoMedia
