| Notices |
Tech@PFC
is Free tech advice
GTR Register Trader
Cars owned: R34 Skyline (Now sold):((
R35 GTR - Slotted discs Front 405mm Rear 381mm
Front and Rear Slotted Disc Upgrades To fit 2011 onwards models of the Nissan GTR we have produces 405mm front discs and a matching slotted rear replacement disc. (These will not fit earlier models due to the calipers having a narrower radius throat) These are the largest disc that will fit the standard calipers and they are manufactured to the same outstanding quality as all our race discs within very tight tolerances. Disc Specifications 1) Patented slot pattern for more bite, improved release, more efficient pad cleaning, and improved thermal stability. 2) High Carbon Alloy with copper and molybdenum for high temperature strength and crack resistance. 3) Aircraft quality heat treatment for micro structure alignment and durability. 4) Runout less than .0005 inches and thickness variation less than .0002 inches reduces Judder and Pulsation. 5) Vanes turned OD and ID for balance to reduce thermal distortion and vibration. 6) 47 or more vanes for superior thermal capacity. 7) Surface finish less than .7 microns for reduced drag and more consistent coefficient of friction. 8) 100% measured and inspected to meet strict tolerance specifications. ![]() These 2-Peice discs use our patented V2 mounting which is a light weight solution with excellent durability that allows for float. ![]() For any further information please contact me via email (uksales@performancefriction.com), call (+44 (0) 1295 221 023) or PM me. Best regards, Charlie
Technical Sales Engineer Performance Friction Europe Tel: +44 (0) 1295 221 020 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
| Tags |
| alcon, ap disc, brake, brembos, disc, disc upgrade, dixcel, gtr, performance friction, rotor |
