ab20000
Chaging stock cermaic turbos
Okay so I'm new on here and haven't yet bought a skyline and some of those I am looking at still have the stock ceramic turbos. What are the options and rough costs around rebuilding them or is it better to buy used steel ones? Are there other bolt on options that are better spec?
MrGT
is think I might want a r32 gtr
Cars owned: series 2 R33 GTR (cold climate spec)
For bolt on goodness i would buy a set of the new tomei turbos that have just come out rated to 600bhp
(about £2000)Or you could bolt on some 2860-5's (about £1400) But both would require spring mods ie injectors, fuel pump, ecu ect All this has been covered before, try a search on the forum other than that google is your friend. Tib
GTROC Area Rep-North West Behold a white GTR, and the man who sat in it was Death and hell followed with him. upcoming Northwest events. Northwest mini meet and photoshoot, (date yet to be comfirmed) |
dan-hipgrave
is Gtr-less
Cars owned: R33 GTR v-spec
Stock fuelling/airflow system is good for ~450fwbhp.
A set of 2860-7's or N1 turbos, and a remap and you'll be sorted. I would steer clear of rebuilt steel internal turbos if your budget allows.
#5 (permalink) | |
ab20000
Assume the r33 GTR and r33 GTR v-spec had the same turbos? Are the R34 turbos better in terms of power and quality? Cheers!
dan-hipgrave
is Gtr-less
Yeh, 33 and 33 v had the same turbos.
Forgot to say about r34 turbos - they too provide a cheap upgrade, but aren't as good as the others mentioned. If you're only after a small power increase then they are a good shout for you.
Red Duke
is driving the GTR, and hoping the snow stays away...
Cars owned: Cliff's R33 GTR & Mazda 6 2.2 Sport Diesel
To save me starting a new thread for a similar question:
I have standard ceramics too, I'm thinking of replacing those with either 2860 -5's or -7's. With my wedding in 8 months, I can't afford to do the injectors, fuel pump, etc. yet too, but I'm not looking to run any more power until I can get everything else sorted anyway. I want to get my intermittent over boosting issue sorted too, and am thinking of booking the car in with Ron, so getting the turbos done at the same time would be good. The car is already mapped for 1 bar (Apexi PFC), so I think I'd only need a tweak on the mapping front. Is there anything else I need to consider? Any thoughts / advice would be appreciated. ![]()
GTR Cook
is loving Stoptech's
Cars owned: R34 GTR
My adivice would be, if your looking to change turbo's, only do it once so save a little extra and do the supporting mods. Try and think where you want the car in a few years time and not in the next 12 months.
450 will seem plenty in the time being but you will get used to it! Just had 2860-5s fitted and lover them!
Red Duke
Thanks Cook
![]() I've already got ~430bhp (360atw) and I'd like 500-600 tops, without needing to go down the route of a rebuild just yet. I'm just after the relative security of newer turbos, I know I'm not pushing mine, but there is always that doubt of "they're ceramics" in the back of my mind. I thought it'd be a worthwhile upgrade, especially if the over boost issue is being caused by something sticking, or not releasing the pressure as it should. I guess I could wait until afterwards, and just buy a couple of bits now and then, cuminating in getting Ron to get the turbos for me after the wedding, and then getting everything fitted and mapped, but I'm an impatient bastard. ![]() Besides, I've been doing OT at work, and getting a bonus for the Olympics, so I'll be damned if that lot is getting sucked into my wedding savings too! ![]()
GTR Cook
Cars owned: R34 GTR
My reason for change was because my rear turbo exhaust wheel broke during a track day, so they do break.
I went for the -5s so that I could go for more power in the future. They will run fine on a standard engine with slightly increased lag and the other bits can be done at a later date. Just do everything you need to in that area at once and most important is the map.
purleskyline
is big single fitted
Cars owned: R33 GTR track/sprint. nissan juke nismo. renault megane trophy. 2.5 vivaro van.
I went from standard ceramics to garratt gt2860-5s,totally standard just a power fc ecu. 478 fwhp.
#12 (permalink) |
Red Duke
Mmmm
![]() Thanks chaps, definitely going to have a think about the -5's, not long until payday, so I'll have to syphon a few quid off to go towards the Garretts me thinks... ![]()
#13 (permalink) |
Rookemonster
Cars owned: R33 GTR, SUBARU JUSTY TWIN CAM, BMW 520d, SUZUKI GRAND VITARA
I had ceramics too, car was tuned to 357 ATW last year with a LinkG4 ECU.
This year had tubbies converted to Hybrid plus injectors, fuel pump, tomie poncams, now makes 450 ATW, massive difference, really pleased. my goal was 500 at the fly without internal mods and minimum lag, so for me Hybrids were the way forward, why spend the cash if you don't need to.
#14 (permalink) |
ab20000
Some good info on here. Newbie question but assume when you say hybrid turbos you just mean different internals? (so in this case steel internals)
