matteo306gti
4wd light turn on...when the car is hot
Hi guys, greetings from italy
i ve a problem with 4wd on my r32 but i seen the light on dash turn on all times i make some kms.....when i have the car in the garage all night and i start the car the 4wd works well, but after about 20minutes or 15km driving the light turn on....and one time the light turn on i can also turn off the car but when i restart her the light turn on immediately.... it seems the problem born when the car is hot.....and when car is cold it s all perfect.... for this reason i thought i can have humidity inside attesa oil system and when the oil became very hot this humidity became air....so the ecu cut 4wd for save transfer.... could be the problem? i checked 4wd fuse but it s ok.....and also oil level is perfect, more high than the max level in the botle... today i would check the red light on grey ecu in the rear, and count the flashes light numbers..... ??? what can be? help me please __________________
carbonfootprint
I had this problem when I first got my latest r32. The previous owned had fitted different makes of tyre front to rear (same size) but it was enough to cause the 4wd to register wheel slip and be always engaged. This can happen on worn rears too. When you drive on light throttle is the front torque gauge reading 0? If not it will overheat and cause problems.
One of many possiblilties
willrobdon
is hardcore BNR32
Cars owned: BNR32 GTR , Mondeo ST 2.2
Have you bled the oil recently?
GTROC Area Rep - South West BNR32 GTR My build: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
matteo306gti
i dont know mate....i just bought the car.....
the car seems very good conditions external and mechanically....but when i use the car and i drive hard for some minutes(normaly i seen about 20 minutes) the light turn on.... i look oil in the rear tank and seems new without leaks..... u thinking a wrong oil or wrong bleeding?
matteo306gti
thank to all for the help.....
today before use the car i checked earths and i tried to move them...than i start the car and also today the light turn off.... normaly when i drive hard the car i seen the 4wd light turn on after about 20 minutes....but today after 45minutes and driving with a crazy i couldnt see the light turn on.... today the car and 4wd working well..... i don t know..... i also checked the red light for faultcode but nothing.....
r32hams
is searching for grip
Cars owned: r32gts4 on gtr shell
If the 4wd light is on but there is no light flashing on the attesa then it has a problem with power,or the attesa unit has broken.check the plugs are in the attesa unit properly as they often don't clip in properly.
RobGalley
Cars owned: White 32 GTR...
Has the car got an add-on 4wd controller? If so these are spliced into the wiring harness in the boot, and could cause a loose connection (I had this).
And as per above the connectors into the controller unit may be loose/corroded, try moving the wiring around (gently) with the car running and see if you can make the fault occur.
HeavyDuty
is glad everyone hates the R33.
Mine's been doing the same thing for a while now. The last time the light didn't come on after a short drive the ambient temp was very low outside, like 20-30 F.
It's on the list of 'to-do's'. I think I'm going to start it up and wiggle the front wheel speed sensors to see if I can get it to come on. The code is the correct way to start looking, I know.
