JDM_Garage
Offline
This week only! 20/07/12
The basics of 'This Week Only'
AEM Boost Gauge -30-35PSI ![]() AEM's Boost Pressure Gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM analog gauges also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or F/IC. FEATURES • Gauge Readout from -30 to 35 psi • Adjustable backlighting via a dial on the back of the gauge • Includes black and silver interchangeable bezels and white and black faceplates • 320 degree viewing area for unsurpassed resolution • Pressure gauge includes high quality sensor - everything you need to install the gauge! • 0-5v analog output included for use with data loggers and virtually any engine management system This Week Only - £135.99 Blitz LM Power Induction Kit ![]() This is the lowest priced of the three types of Blitz Induction kit available but don’t be put off by the cheap price, the filter element is made from a durable, light weight cotton gauze. Filtration is very good and with it being a dry filter there is no need to re-oil the element when you reach a service interval, you simply through it away and replace it with another (oil from oiled filters can gradually disperse into the air inlet and coat the air flow meter reducing the performance of the vehicle and damaging the air flow meter). The replacement elements are available in three different colours, blue (which is supplied with all new kits), Yellow, and Black. With the elements costing under £29 to purchase it makes this kit a very affordable entry to Japanese tuning. The LM induction kit comes complete with a tailor made fitting kit for the specific vehicle. This Week Only - From £70.00 Exedy Organic Clutch Kit ![]() Exedy Corporation of Japan is one of the largest OEM Clutch Manufacturers worldwide. Exedy supplies all eleven Japanese Vehicle manufactures as well as Ford and GM in the United States. Exedy is also the leading manufacturer of performance clutches in Japan and supplies all six-factory vehicle manufactures race performance clutches in Japan. All Exedy race and performance clutches are engineered, designed and built from the ground up as performance clutches. These units are designed in the shadow of the OEM application. This allows for ease of installation with no major modifications. Exedy clutches are not rebuilt or modified stock clutches like many of our competitors. Exedy’s product innovations are patented worldwide and developed in house using state of the art design, inspection and testing equipment. Before any design goes into production it goes through rigorous tests that simulate severe driving conditions, which ensure perfect performance in your vehicle. Additionally, no part will leave the Exedy warehouse without a robotic and visual inspection, which guarantees quality you can stand behind. This Week Only from - £229.99 HKS Super Power Flow - Replacement Filter ![]() HKS replacement Filter Elements are available in a dry 3-layer, triple density or wet 2-layer, dual density construction. The dry 3-layer type is standard in SMF Reloaded Intake kits, and is designed for superior filtration while still providing excellent airflow. The wet 2-layer type is included in Racing Suction kits and is focused on maximizing airflow for performance, yet still keeping harmful particles from the engine. If your vehicle is in a high dust area, HKS recommends using dry 3-layer elements. This Week Only from - £19.49 Koyo Racing Radiator ![]() The Koyo Type Z radiator has been designed for the highest levels of cooling required for competition and can be seen in D1 drift, top circuit and drag cars. Suitable for top level competition level performance All-aluminium 2 layer aluminium core 35% improved heat dissipation compared to normal 53mm core thickness As seen in countless top level competition cars throughout Japan and the world High durability construction designed for easy vehicle fitment This week only from - £294.99 Nardi Deep Corn Steering Wheel BLK Suede Red stitch BLK spoke 330mm ![]() 350mm 80mm Offset (Dish) in black suede leather with red stitching and black spokes. This Week Only - £160.99 Nissan S14A URAS Full kit ![]() Nissan S14A URAS Full kit This Week Only from - £492.95
JDM Garage Recieve 10% discount from our online store! tel. 08450NISSAN or 01237 432952 email. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. web. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
