Oil on top of piston - Page 2 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Maintenance
Notices
Old 28th July 2012, 10:27 PM   #16 (permalink)
Phil69 is praying for sunny weather so he can polish the Skyline
Phil69's Avatar
Cars owned: Skyline GTR R33 V-SPEC
This might sound lame but, how do I do that? Not something I've tried before.
Phil69 is offline   Reply With Quote
Old 28th July 2012, 10:33 PM   #17 (permalink)
R32 Combat is in limbo
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
You need an air compressor and a leakdown tester. It's a much better was of testing how well the combustion chamber is sealed. Google it.
SKYLAB FUSION. The 3rd generation torque split controller for the ultimate driving experience.
This replaces your old G-Sensor for a digital, faster responding, unit along with offering the driver the ability to alter the balance of the cars 4WD power delivery for the optimum balance.
A free fitting service is available at Skylab HQ, which is postcode RG19
Limited offer Only £185.
including p&p worldwide tracked postage
Also available in the GTROC online shop
Old 28th July 2012, 10:34 PM   #18 (permalink)
Phil69's Avatar
Ahh right. I get it now. I assume it holds the pressure in so you can watch it over a period rather than the quick blast of pressure as you crank the engine for a compression test.
Thanks for your help!
Old 28th July 2012, 10:38 PM   #19 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
I hope you get it sorted.
Old 28th July 2012, 10:48 PM   #20 (permalink)
DrGtr is unaware they can edit their status
DrGtr's Avatar
just start with a check list of a couple of things, leak test , even though if you have a good symmetrical compression test i would just unbolt the turbo first and be sure that its not the seals , i dont have the experience but my opinion is that is the turbo.
DrGtr is offline   Reply With Quote
Old 28th July 2012, 10:51 PM   #21 (permalink)
Phil69's Avatar
I already removed the front turbo and there is oil coming through the exhaust port into the manifold so the oil is from before the turbo plus, as said before, the inlet pipes are clean and there is oil on the piston.
Old 30th July 2012, 02:07 AM   #22 (permalink)
xxfr is hibernating
Sometimes the oil in the cylinder above the piston tends to seal and hold pressure, enough to give false compression readings. Do the leak down test as that will give you a better result.
I have seen in big truck engines when rings give up and they start using oil like hell. The oil ends up in the cylinders from the bottom through around the rings and up. Put the same pistons back in with new rings and problem is solved.
xxfr is offline   Reply With Quote
Old 12th August 2012, 07:10 AM   #23 (permalink)
bucharest is 92' gtr.
bucharest's Avatar
i think maybe your turbo let go and the wet piston may be a different issue. one thats not such a big deal. how much oil on top we talkin bout tho ? and did plug 2 actually have oil on and look different than the rest ? and plus 1 for a leakdown test.
bucharest is offline   Reply With Quote
Old 12th August 2012, 08:37 AM   #24 (permalink)
Mark@Abbey M/S is looking forward to racing on the circuits again soon
GTR Register Trader
Mark@Abbey M/S's Avatar
Cars owned: Skylines...
Wet piston top as long as it isn't swimming in the liquid I wouldn't worry, when you run a car and turn it off and pull the spark plugs your see the top of the pistons still damp.
If you put #2 cylinder to TDC can you put a long screw driver down the plug hole and touch the fluid and then inspect it?
If you have neat oil in the down pipes and good compression's I would say you have a turbo failure.
It does all seem strange that the car was running lean before you have the failure thou as these 2 items aren't connectted at all.
Servicing/tuning all Skyline models since 1990
Ecutek/Cobb/Syvecs and Up Rev approved tuners
In house Dynapack dyno
Up to date diagnostics for all Nissan,s Consult 1/2/3
Laser 4 wheel alignment equipment
Corner weight scales for trackset up
Tuner of the fastest Rb26 powered car in Europe
Any information needed give us a ring or mail us
Old 12th August 2012, 08:46 AM   #25 (permalink)
GTR Register Trader
Sorry just read the oil is coming down the exhaust port, no the turbo outlet.
Can you see where the oil is coming from? Is it coming down the exhaust valve guide?
Leak down test definite, look down the bores with a good endescope as well, any piston damage will also damage the cylinder bores as well.
Mark
© 2001-2013 Cem Kocu
demoMedia
