luchjeg6
Exhaust manifold issue
i'm starting to hear a sound clearly coming from the exhaust manifold, I think the rear one... Is it possible that it has broken or it's maybe just a loosened nut?
Marky_GTSt
is a Fire Engine
Cars owned: Skyline GTSt
If its a stock manifold there is every chance its just loose or the studs broke or gasket blown.
Either way its going to have to come off really, If you cant find the cause on stripping it then look for cracks.
I am Jacks complete lack of surprise. |
#3 (permalink) | |
MGT Racing
GTR Register Trader
Hi mate Most of the time, it is either the Exhaust manifold gaskets or the turbo to manifold gasket that has gone. You may be lucky if it is the nuts that have came loose, but, if, as is most likely, it has blown the gasket out now, this will mean you will have to take both of the turbos off to put new gaskets on. Hope this is of help to you. Regards Mark
Winner of the 4 wheel drive class in the Classic Thunder Saloons Championship 2012 Since 2004 we have been Servicing/tuning all Skylines models 32-33-34-35 4WD Dynapack chassis dyno Lazer 4 wheel alignment Corner weight for track set up and road set up In house Tyre Fitting and Nitrogen Filling LINK Dealer HKS- Fcon Dealers ECUTEK-PRO Ecu Tuners COBB Accessport Race Tuner Check out our website at To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Tel: 02476 398344 or 07779 117236.
r32hams
is searching for grip
Cars owned: r32gts4 on gtr shell
I would recommend taking it off,and having it skimmed before replacing all the studs broken or not.the heat makes the studs brittle and the manifolds warp over time but once its skimmed it will be good.
luchjeg6
Am I forced to take off turbos to take off manifolds? If yes I'm planning on changing them, maybe the new tomei kits
![]() What do you guys say? I would like to reach 550 now I'm 400 on stock turbos. But I don't wanna raise the lag
luchjeg6
I found the leak, it should be the gasket between the turbo and the pipe that connects to the downpipe, the rear one, is it possible to take it off almost easily?
