| Notices |
ian turbo
is Driving a R33 GTR, V-SPEC . 600R 2.8 hks stroker.
Corsa 1.8 as 2nd car .
Cars owned: skyline gtr
Replaced inlet gaskets. Now car wont idle & no boost ??
OK i have had a boost leak for a wile now So i thought lets get it sorted.
Got new hks gaskets so took inlet off cleaned up the throttle bodys fitted gaskets Put inlet back on now car runds like crap & i must a a vacuum leak as dont get no boost at all. Ive checked all hoses. Ive just had the injectores cleaned. one is running 100 cc more then it should be. But i also changed the vacuum thing where the vacuum pipes go at eather end.. the one at the side of rocker cover. that seams to be tight as im getting vacuum from there. Ive been out there the last 2 days tryin g to find this problem now. and its doing my head in.. Anyone have any ideas what this could be.. Many thanks Ian.
Midnight Liner
is no longer selling his GTR :)
Cars owned: R33 GTR, Scooby WRX
Did car idle ok before you changed out the gaskets?
I see you have checked all hoses so no splits on them. Possible you have put hoses to the wrong place? Any sensors still disconnected or anything? Maybe take a picture around the plenum and throttle bodies to see if someone can spot something that might be wrong or off with pipes connections etc. Sorry can't be more help mate.
carbonfootprint
Apart from stating what you already know, you seem to have a leak!
Have you considered removing everything and starting again? To get no boost at all in the plenum means the leak is substantial. Again I'm sure you know all this! Have you considered water with some detergent in a spray bottle + loads of revs to try and make bubbles and you should hear a change in idle?
#5 (permalink) | |
ian turbo
As there is one pushing out 840 where the other five are 744 ??? And should i take the 840 one out and put it in number 6 ??
gtr-loz
is cold
If it was fine before you started then as a general rule it's something you have done
Did you get the dowels on in the correct order as the ones from the inlet manifold to he bodies are a different size to the ones on the throttle bodies to the plenum maybe you have them round the wrong way and are holding off the manifold slightly at the bottom
ian turbo
Never undone the dowels. left them on just tied it back.
ian turbo
Well i have someone coming round tomorrow to help look for the problem.. Il let you know what we find.. lol not that we will as ive been out there 2 days going over everything that i had done..
DazGTR
is a CAP-END who enjoys the company of lady boys
Cars owned: KH2 R32 GTR Project
when you say you cleaned the throttle bodies with carb cleaner and a tooth brush did you clean the gunk from around the butterflies ( 2 per throttle body ) ?
ian turbo
Yes there was crap , all around the butterflies . So cleaned them wile I was there.
I think I'm going to have to take the inlet off again to see what has happened. :-( Not happy bunny :-(.
#13 (permalink) |
ian turbo
So what your saying is , the old bits of oil and crit that was stuck on the butterflies in the corners is a good thing to have in there ? As when I was opening & shutting them you could hear crap scraping the butterflies ?? Ok then. I thought they would open & shut more better if they was clean.
#15 (permalink) |
ian turbo
Ok well I've been out today & the idle seems to be fine. It's only when I rev it it sounds rough . Whati want to know if. I take the inlet off again will I need new gaskets or can I reuse the new ones I have just put on ?
