Do Luck designed a brand new ignition wiring loom for the RB26DETT.
We all know the OEM wiring to the coils. If the wires are old, the connectors break if you try to pull them off the coils, the wires are completely stiff and not flexibel anymore and sometimes the wires even changed colour due to the heat and age!
These wires are the crucial parts which send the signals to the coils before they ignite the sparkplugs. If these signals are not as strong as they should be, it makes your engine run poor or not 100%.
When tuning your car, it's important you make sure all basics are 100% before asking your engine to give 100%.
Do Luck designed a brand new harness for the R32 GTR, R33 GTR and R34 GTR. Using OEM connectors OEM quality connectors and 60% thicker cables for a stronger signal.
Besides the new harness, the kit will come with the direct power supply. A direct connection from the battery + to the coils optimizes the signal and keeps the signal consistant. Of course the kit will come with it's own earthing wire aswell.
Do Luck Japan:
The popular RB26DETT engine ignition system can show weakness when tuning for optimal efficiency.
The Do Luck Iginition harness kit overcomes such weaknesses.
Increased wire thickess for maximum power:
In order to transfer the ignition signal with maximum strength and efficiency, all wires have increased thickness (1.6x thicker) over the stock wiring harness. Particular attention has been paid to power and earth lines for maximum power delivery for the strongest ignition signal. Do-Luck has considered ease of use for tuners too by providing a long ignition signal wire for easy connection of devises such as timing lights.
Individual applications for each model:
Do-Luck makes installation of this harness as easy as possible with sperate kits for R32, R33 and R34 applications. With the correct vehicle kit, no cutting or soldering is required for installation.
Optional direct power harness for further improved ignition strength:
For further ignition signal strengt, Do-Luck recommends the use of this direct power harness. Taking power direct from the battery, the signal can be further strengthened. A thick earth canle supports the increaded power input.
There are 3 kits available, one for every car model.
R34 GTR RB26DETT: Do Luck Hyper Ignition harness kit Nissan Skyline R34 GTR BNR34 - PartBox Performance and Tuning
R33 GTR RB26DETT: Do Luck Hyper Ignition and Harness Set BCNR33 - PartBox Performance and Tuning Parts
R32 GTR RB26DETT: Do Luck Hyper Ignition harness kit BNR32 Nissan Skyline R32 - PartBox Performance and Tuning Parts
We have all sets in stock, ready for immediate shipping (from NL office).
Some product pictures:
Connector to coils:
Direct power feed:
OEM connectors:
Harness:
