Best thing to do here is look on the BT website to see if your number is enabled for broadband (obviously it is), but it tells you the speeds you can have.
But you can tell them (wanadoo) to just put the order for 1mb through - they will contact BT who will have to do a line test to see if 1mb is possible, then if its not you cant upgrade - simple as.
But yeah - that is utter 5hite!!
