3: You can "recycle" the AFM-connectors from the R32-units, Just desolder the connector pins inside the housings of respecive units and swap, as they are "identical" internal connections. (Number of pins differ in connectors sockets, but the extra pin in Z32:s is not electrically connected and thus not used). Take care when carefully "opening" (using sharp knife) the AFM:s sealed/glued square top covers so nothing brakes.
Great, I see they are actually the same part it's just the outer plastic *tube* that is required.. must be able to fabricate these.... in addition do you use your exisiting loom & connnectors? If you use the Z32 do I simply splice in the block connectors?
Apexi Super Suction: http://www.nengun.com/image/catalogu...product-99.jpg
So this is simply an induction kit for either AFMs or this is custom sized for use with the larger AFMs sorry I don't understand why this is now needed
4: If using PFC you basicly select the VG30 AFM in the apprpriate menu, and proceed with mapping in normal way.
Straight forward enough then.
// Lars[/QUOTE]
