Originally Posted by RB_26
Great, I see they are actually the same part it's just the outer plastic *tube* that is required.. must be able to fabricate these.... in addition do you use your exisiting loom & connnectors? If you use the Z32 do I simply splice in the block connectors?
I do not use Z32-utits at the moment, but by "recycling" the R32/33-connectors from std-AFM:s you do not require any loom-modificatins whatsoever.. should be applicable för R34:s also I believe.
(Mod-tips originally from a GTR-forum user who actually did fit Z32:s on his R33, so AFM:s are internally interchangable with the different connector designs)
