| View Poll Results: What make of tyres do you use? | |||
| Goodyear |
92 | 12.94% |
| Continental |
24 | 3.38% |
| Toyo |
130 | 18.28% |
| Pirelli |
32 | 4.50% |
| Michelin |
30 | 4.22% |
| Dunlop |
41 | 5.77% |
| Bridgestone |
160 | 22.50% |
| Avon |
17 | 2.39% |
| Yokohama |
75 | 10.55% |
| Falkens |
110 | 15.47% |
| Voters: 711. You may not vote on this poll | |||
LinkBack | Thread Tools |
Rating:
Display Modes |
#139 (permalink) |
In the process of buying some tyres guys......anyone used Dunlop SP9000's??
Going for 275-30-19........wheres the cheapest place to buy???
Too often we lose sight of life's simple pleasures. remember, when someone annoys you it takes 42 muscles in your face to frown. but it only takes 4 muscles to extend your arm and bitch-slap the motherfuNker upside the head. ----------------------------------------------------------------------- Blown by a T04z - built and mapped by Tweenierob ..... http://www.junsuperlemon.co.uk http://www.neweraimports.com |
#142 (permalink) |
Decided to go for Falkens guys......managed to get them at a really good price. Thanks for the advice.
#143 (permalink) |
I've always used Kumho Ecsta Supra 712s - recommended to me by Callum Lockie and always been a pretty reasonable compromise - cheap and ok grip and ok-ish on track both wet and dry (but I don't hoon).
I've always used Micheldever tyres (01962-774-437), either gone down there and had them fitted or got them to deliver to my local fitter - prices have always been rock-bottom. http://www.micheldever.co.uk/ Fox --- Not in league with Micheldever, own shares etc. etc. |
#144 (permalink) |
Last car was on Bridgestone SO2/3 which were excellent once warmed up. Had Pirelli P-Zero on the new car until blowout two weeks ago but had not been that impressed with them. Now have fitted G/Y Eagle F1's as the Bridgestones not available in my sizes in this country and G/Y's are highly recommended on Supra forum. Prooving good at the momment but have not tested thoroughly enough yet.
#145 (permalink) |
I've just got my GTR R33 V Spec. Its Got some Potenza RE01's on it.
I'd like to go for 285/35 R18's. Would that work ? My car has Nismo suspension as well. Am considering Toyo T1R's, Falkens 451's or F1's. I won;t be doing many miles approx 3k per year. Not too worried about wear just good grip and handling in dry and wet What do you reckon ? Thanks |
#146 (permalink) |
Bridgestones all the way ...going back in time to my scooby days, I had some really worn bridgestones, thought it was time to replace .. so being a bit tight fitted a brand new set of Yokohamas ... well suffice to say they gave alot less grip than my knackered bridgestones .. to the point that I did a nice big 720 spin whilst accelerating and went looking for the nearest hedge ...
luckily only got a few scratches and a b*ggered tow hook .. I promptly ditched the yokohamas and bought S02's .. |
#147 (permalink) |
Hi All,
Just to confirm that Toyo Proxes are a good tyre but do wear out ver quickly. I have only had them on for 7 months and all 4 have worn off, I had tracking done and it seems that I need a Camber Kit. Could someone advise where I can get one? What does the kit consist off? Apoligise if this is in the wrong section. Regards, Rich |
#148 (permalink) |
You can get cheap camber kits from a company in Aus called Whiteline. Put a set on the rear of my car and sorted the camber problem (normally due to lowering the car). The one I got consisted of an eccentric bush giving the correct camber adjustment. I believe Abbey are now stocking these (since seeing mine) and would recommend getting them to set-up the car geometry as mine was a different car afterwards.
#149 (permalink) |
GTROC Member 489
Any tyre will wear out quickly with bad wheel alignement
Try Abbey for a Whiteline camber correction kits ![]()
Geoff - Rising Sun Performance tuned R34GTT RB30with a T04Z - 675bhp 574lbs all through the rear wheels........... |
