At big revs the oil pump is moving a lot of oil though the motor. The higher the revs, the more oil.
You suck all the oil out of the pan, run dry and spin a bearing.
What I have seen anyway.
I would be interested to look into a motor spinning big revs and spraying oil at the underside of the piston.
I noticed Cadiliac is even putting oil squirters in their supercharged Northstar motor. They say its worth torque and horsepower due to their ability to run more advance.
