What Viscosity Oil do you use in your Skyline - Page 17 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
View Poll Results: What "viscosity" oil do you use in your Skyline
0w-40 30 3.58%
5w-40 111 13.25%
10w-40 144 17.18%
10w-50 131 15.63%
10w-60 155 18.50%
15w-50 203 24.22%
None of the above 64 7.64%
Voters: 838. You may not vote on this poll
Old 14th January 2008, 07:35 PM   #241 (permalink)
DUNCAN GT-R has no status.
DUNCAN GT-R's Avatar
Cars owned: R33 GT-R V-SPEC
Originally Posted by oilman View Post
Hhhmm, interesting... No reason I can think of at the moment for it.
Thinking cap is on though.
Guy.
Yeah, filler cap on and engine running great.
DUNCAN GT-R is offline   Reply With Quote
Old 22nd January 2008, 09:51 AM   #242 (permalink)
GarethK has no status.
GarethK's Avatar
Cars owned: R33 GTR V-Spec x2
Originally Posted by DUNCAN GT-R View Post
Did my oil change this morning to find that the oil pressure is higher than before with the thinner oil.
I used to use Silkolene pro R 15-50. when the oil was up to temperature it would idle at just above 2 bar. Now with the Silkolene pro S 10-50 it idles at 3 bar pressure when hot.
Would this be right ????
Was it 2 bar when the 15W-50 oil was NEW - or just before the change? Oil dilution will cause a reduction in viscosity and 'range' over time, and can be a good indicator of when an oil change is due. This means that over time / a few thousand miles your 15W-50 might end up being a 10W-40 - with a corresponding drop in pressure for the same flow.
Old 22nd January 2008, 01:09 PM   #243 (permalink)
oilman has no status.
oilman's Avatar
Cars owned: Mazda RX8
Yep, could be fuel dilution.
oilmans website :
e-mail :
tel : 01209 215164
Old 5th February 2008, 07:24 PM   #244 (permalink)
chiba_kun is heavily addicted to the Skyline
chiba_kun's Avatar
Cars owned: 1995 R33-4door GTS4 with RB25DET
First I was using fully synthetic ELF 0W40, but now I am using MOTUL 300V Competition 10W50. It really makes a difference (much better!!).
chiba_kun is offline   Reply With Quote
Old 5th February 2008, 07:54 PM   #245 (permalink)
oilman's Avatar
I think you'll find it's 300V Competition 15w-50
Decent oil
Simon
oilmans website :
e-mail :
tel : 01209 215164
Old 6th February 2008, 10:30 AM   #246 (permalink)
chiba_kun's Avatar
Decent oil
Simon
Sorry Simon! My wrong... You are totally right, it is 15W50>
Old 6th February 2008, 02:37 PM   #247 (permalink)
mwebster is winning time attack club pro
mwebster's Avatar
Cars owned: R32 Race Car, R33 GTR, R35 GTR
Question
I was using Motul 15-50 but cant seem to find it in south germany where I am for now , any ideas on the best source over here or a good alternative that is available locally ?
Thanks
Marcus
mwebster is offline   Reply With Quote
Old 12th February 2008, 05:20 AM   #248 (permalink)
gtrdave has no status.
Nissan recomend a 7.5w 30 oil for a standard BNR32. So I wouldn't go too far away from this. This is how I think of it. The thiner the oil, the easyer it is feed through your engine and the more oil you should have on your engine internals. The oil in your engine has to travel through little holes. Say you had a cup filled with oil. The cup has a hole in the bottom, the thiner the oil the more oil that will get through the hole. So I always try to stay close to what nissan recomend. That is how they designed the engine and they should know, as they have tested what was best. The next thing is different brand give different levels of protection for the same grade oil. That one I can not help you out with. But don't buy cheep oil. Stick with something you trust. I like mobil, pentrite and motul. Hope that helps
gtrdave is offline   Reply With Quote
Old 12th February 2008, 06:02 AM   #249 (permalink)
Toluene Junkie
kismetcapitan's Avatar
that's exactly the rationale behind me using 0W-20 oil. It's Motul 300V so it's damned pricey stuff. I don't run on the track and I've got an oil cooler so I've never been able to realy cook my oil up to 90~100 degrees. During summer though I'll move to a 40 weight oil - but I'm going to experiment with placing an electric fan on my oil radiator, and add some inlet and outlet ducting and see how long into the spring I can run the thin stuff.
Old 12th February 2008, 08:25 AM   #250 (permalink)
I was told (so it's not me and I'm not to be quoted on this but) that your oil should be the same temp as your water 90deg. I was told this by someone who set up race cars as well as street cars.
Old 12th February 2008, 12:02 PM   #251 (permalink)
Toluene Junkie
I've gotten 90 degrees oil temp during the summer, but I don't think I've ever gotten my water that hot, except with the A/C on and not moving in an August traffic jam....and I have a stock radiator!
Old 12th February 2008, 04:13 PM   #252 (permalink)
oilman's Avatar
Thanks
Marcus
Try us
Opie Oils - Performance and Heating Oils discounts for GTR Members as well
oilmans website :
e-mail :
tel : 01209 215164
Old 12th February 2008, 04:16 PM   #253 (permalink)
oilman's Avatar
These cars in unmodified form on the road should run happily on a 5w-30 or 5w-40 however there are many that need something a bit more beefy due to modifications and or use/abuse!
You know that you can always contact us for the best advice
Simon
oilmans website :
e-mail :
tel : 01209 215164
Old 24th April 2008, 11:46 PM   #254 (permalink)
Zabijak has no status.
Zabijak's Avatar
Cars owned: BNR32
Simon
PM me about your prices including shipping to Finland?
Zabijak is offline   Reply With Quote
Old 25th April 2008, 04:01 PM   #255 (permalink)
oilman's Avatar
How much are you looking at?
Guy.
oilmans website :
e-mail :
tel : 01209 215164
© 2001-2009 Cem Kocu
