View Poll Results: Your dream Engine
RB28 116 23.87%
RB30 168 34.57%
TOMEI 77 15.84%
JUN 69 14.20%
Top Secret 130 26.75%
NISMO 74 15.23%
Big Single 74 15.23%
Twins 163 33.54%
Gas 68 13.99%
No Gas 62 12.76%
Multiple Choice Poll. Voters: 486. You may not vote on this poll
Old 4th May 2005, 08:20 AM   #46 (permalink)
Sounds cheap
But REALLY disagree with you on the piston squirters. In my opinioin they are VERY important and certainly not a waste of oil. Especially at big bhp, they are vital.
Cord
Old 8th May 2005, 10:28 AM   #47 (permalink)
Originally Posted by Cord
Sounds cheap
Cord
...and at big revs; they're fatal.
Mario.
MarioGTR is offline   Reply With Quote
Old 11th May 2005, 08:27 AM   #48 (permalink)
Mario.
Care to expand a little further?
Old 11th May 2005, 03:06 PM   #49 (permalink)
tyndago's Avatar
At big revs the oil pump is moving a lot of oil though the motor. The higher the revs, the more oil.
You suck all the oil out of the pan, run dry and spin a bearing.
What I have seen anyway.
I would be interested to look into a motor spinning big revs and spraying oil at the underside of the piston.
I noticed Cadiliac is even putting oil squirters in their supercharged Northstar motor. They say its worth torque and horsepower due to their ability to run more advance.
Old 12th May 2005, 01:58 PM   #50 (permalink)
I suppose lack of oil could be an issue if running mega rev's like Mario (11,000???) But upto 9500 or so i think with adequate mods to the oiling system and an increased capacity sump it isn't a problem.
Mind you this is an "ulitmate engine" thread so you probably will all want to be running 12,000rpm
Old 25th May 2005, 09:02 PM   #51 (permalink)
An "ultimate" engine will be dry sumped, anyway. The best ultimate engines are the ones you build for someone else, spending their money and making a profit on it
Old 26th May 2005, 10:25 PM   #52 (permalink)
paul cawson's Avatar
This is One I bid on last week. I was saved from buying it by the vehicle inspector because of engine noise. They now know to buy in any condition if the car of the right spec comes up. Sad story, very sad if you read Japanese.
http://uk.pg.photos.yahoo.com/ph/pau...bum?.dir=/5e6b
Old 27th May 2005, 08:28 AM   #53 (permalink)
Hugh Keir's Avatar
Paul,
That looks like it was quite a car, what auction was it sold at?
Thanks
Hugh
Old 27th May 2005, 05:43 PM   #54 (permalink)
It was in HAA Koube, or USS Okayama
Old 28th May 2005, 10:29 PM   #55 (permalink)
Hugh Keir's Avatar
Paul,
I can look back at cars sold at HAA Kopbe and it doesn't look like it was there, the auction sheet is also slightly different at HAA to the one you posted.
I can't look back at the USS auctions.
There is no power steereing and no electric windows, it looks like it was a drag oinly car.
How much did it sell for?
Old 29th May 2005, 12:05 AM   #56 (permalink)
R33_GTS-t's Avatar
Location: [544] days from disposing of Labour. BNFL are shit. One repossession, one (bank) window.
Absolutely no cost limit? Okay...
Engine designation: Nissan RB26DETT: 2.6 litre, Double overhead cam, Electronic fuel injection, Twin Turbo
Displacement: Bored and stroked to 2,700cc
Bore x Stroke: 87mm x 75.7mm
Redline: Exceeds 13,000 rpm
Boost: Exceeds 3.3 Kg/cm2 (Stage 1 was 2.2 Kg/cm2)
Electronics:
GReddy 80mm 3.5Kg/cm2 dual input boost gauge
MoTeC M800 ECU and complete logging sensor array with EGT (x2), IAT (x2), Knock (x2), MAP (x2), wide band O2 (x2), launch, traction and air shifter control
MoTeC Advanced Dash/Logger system
MoTeC CDI/8 channel ignition spark amplifier
MoTeC uprated high intensity ferrite coil packs (x6)
MoTeC complete sensor array and logging of over 50 parameters (shock travel, G's, all fluid temps and pressures in engine, gearbox, diffs, etc)
Bottom end:
Custom 87mm AB-134 (Aluminium-Beryllium hyper-alloy) forged pistons (x6)
Custom ceramic coated tungsten-carbide main crankshaft bearings (x6)
Custom oil cooling system
Custom titanium connecting rods (x6)
GReddy lightened alloy pulley set
GReddy 12 litre enlarged sump
HKS /ATI twin ring fluid-based harmonic balancer
JUN full stroker shaved counter balanced crankshaft
JUN GT spec enlarged radiator
JUN high capacity oil pump
JUN oil sump baffle plates
JUN strengthened connecting rod bolts
JUN strengthened main crankshaft bolts
Nismo N1 uprated water pump
Top end:
Custom camshafts
Custom head channel modification and complete proprietary GT cooling system upgrade
Custom oversized Inconnel exhaust valves (x12)
Custom porting and polishing of cylinder head and runners with extensive flow bench profiling
HKS exhaust manifold gaskets (x2)
HKS metal head gasket
HKS vernier cam wheels (x2)
JUN brass valve guides (x24)
JUN camshaft bearing set
JUN GT surge tank (inlet plenum) with customised bell mouth entries and tuned runner design
JUN intake gaskets (x3)
JUN oversized intake valves (x12)
JUN strengthened head studs (x14)
JUN tappet shims (x24)
JUN titanium valve retainers (x24)
Mines triple baffled cam cover plate assemblies (x2)
VeilSide 100mm throttle body assembly
Turbo system:
A'PEXi Drag Vmax/SPL Pro intercooler (718mm wide × 277mm high × 156mm thick) with two 80mm inlets and one 100mm outlet
Custom dual 3.5" exhaust dumps, separate wastegate pipes into single 2.5" dump, exiting after front-left wheel
Custom turbo piping of 80mm turbos (x2) to intercooler, 100mm from intercooler to 100mm throttle body
Custom turbo system oil feeds, water cooling lines and modification of GT bearing cores to support higher shaft speeds
GReddy Type-R Racing Blow Off Valve, with 3.0Kg/cm2 spring
HKS 58mm external GT-Pro spec wastegates (x2)
HKS 150mm to 100mm anodised aluminium bell mouth funnels (x2)
VeilSide/GT exhaust manifolds (x2), split as 2 banks of 3 cylinders, each feeding one turbocharger and an external wastegate
VeilSide/SPL GT-3540 turbo chargers (x2) with uprated customised GT-42 compressor wheels and compressor/exhaust housings
Fuel system:
Bosch Motorsport 850HP fuel pumps (x3)
-80 braided fuel feed lines (x3)
-60 braided fuel return line
Custom 2,000cc injectors (x6)
Custom 20 litre fuel cell, with competition spec re-breather system
Custom oversized and multi tapped fuel rail
MoTeC in-line high-flow fuel filters (x3)
SX 6.0 bar high pressure fuel regulator
Drive train:
ATS carbon triple plate 9.0" clutch
ATS front 1.5 way carbon LSD
B&M air shifter modified for control via MoTeC ECU
Cusco rear 2.0 way high-lock rate Drag/SPL LSD
Custom solid engine mount system
HKS/Berc uprated drive shafts, front (x2) and rear (x2)
Holinger 6 speed sequential drag gearbox with uprated spline input shaft
JUN modified hi-torque transfer case system
Nismo N1 drive train mounts
VeilSide hydraulic torque split control system
Aerodynamics:
Custom low drag rear wing assembly
Do-Luck front aerodynamic under tray diffuser
Do-Luck rear bumper bar and aerodynamic under tray diffuser
JUN GT aero vented bonnet
Trust drag front bumper bar with extensive modifications
Suspension:
Modified VeilSide Pro-drag coil over suspension system
JUN Pro-drag/SPL coil over suspension system (for Pro-GTR class)
Multiple strut bracing and body work strengthening
VeilSide Pro-drag coil over suspension system (for street tyre class)
Brakes:
ATS carbon race rotors, front (x2)
ATS carbon brake pads, front (x2)
Endless CCM brake pads, rear (x2)
Custom braided brake lines
Simpson 200mph parachute
Interior:
Bride Zieg Carbon-Fibre/Kevlar race seats (x1)
Chrome-moly 6 point (competition certified) roll cage
Sabelt Indy 5 point 3" harnesses (x2)
Weight reduction:
Custom acrylic replacement windows
Custom CFRP lightened boot
Custom CFRP lightened doors
Extreme stripping and weight loss program
Wheel rims:
BBS Le mans' LM limited edition, forged, (Gold) 18" x 10.5" for normal street tyres (x4)
Rays Advan RG, forged, (White) 15" x 8" for Pro-GTR drag slick class (x4)
Racing Hart CP-035R, forged, (Gold) 17" x 10" for street tyre drag class (x4)
Old 29th May 2005, 12:27 AM   #57 (permalink)
Originally Posted by Hugh Keir
Paul,
Thanks
Hugh
Hugh it was through these people http://www.auctions.bonsaicars.com/ if you say it was the car I bid on they should have a record of it. It had plastic windows like a drag car but twin fuel tanks. Start price was 250000 yen.Only went through last week. I would have brought it repaired the engine over the winter I bid £8500 had to be worth that ? would have used it for the track only. I dont know how much it when for , you have to go in with a XX bid or the vehicle inspectors will not bid on a faulty car.
Old 30th May 2005, 12:47 AM   #58 (permalink)
Haribo's Avatar
Send a message via MSN to Haribo
r33 gtst boy wats the point in copying and pasting neatly exactly mario's spec list
Haribo is offline   Reply With Quote
Old 30th May 2005, 02:36 AM   #59 (permalink)
Cause he wants to suck him like michael jacko on a teenage boy with cancer
Deffo enjoying the RB30 love, nice to see people have sence, make me the right offer and you can have mine
Old 7th June 2005, 02:22 PM   #60 (permalink)
skylinelee's Avatar
rb30 love.............lol
skylinelee is offline   Reply With Quote
