View Poll Results: Your dream Engine
RB28 116 23.87%
RB30 168 34.57%
TOMEI 77 15.84%
JUN 69 14.20%
Top Secret 130 26.75%
NISMO 74 15.23%
Big Single 74 15.23%
Twins 163 33.54%
Gas 68 13.99%
No Gas 62 12.76%
Multiple Choice Poll. Voters: 486. You may not vote on this poll
Old 15th February 2005, 03:23 PM   #1 (permalink)
empi's Avatar
Send a message via MSN to empi Send a message via Yahoo to empi
If money was no object - What engine and spec
Would you choose?
Displacement:
1. RB27
2. RB28
3. RB30
Prefered tuner:
1. Tomei
2. JUN
3. Top Secret
4. Nismo
Turbo's:
1. Twins
2. Big Single
Intake:
1. Single Throttle
2. Standard plenium
3. Surge Tank
ECU
1. F CON PRO V
2. Motec
3. Other
empi is offline   Reply With Quote
Old 15th February 2005, 03:33 PM   #2 (permalink)
If was V-Max or 1/4mile and there was absoloute no limit on costs of anything (inc transmission) then id stick to a RB26, tho you havent mentioned it as an option.
For road and track use, esp with a decent road useable gearbox, id choose RB30.
Apart from that i cant be arsed going into details as its silly.
Old 15th February 2005, 04:35 PM   #3 (permalink)
RB26
Tomei
Twins
Nismo Plenum (not mentioned, i know)
Motec
GT-Rob is offline   Reply With Quote
Old 15th February 2005, 06:28 PM   #4 (permalink)
NITO's Avatar
RB28
Top Secret
Single
Nismo Plenum
HKS F-Con V Pro
Old 15th February 2005, 07:37 PM   #5 (permalink)
IanH's Avatar
Send a message via MSN to IanH
The Mines setup for an everyday car or this for race/drag engine
RB30 OSG
Top Secret
Twins
GReddy Plenum
Motec
IanH is offline   Reply With Quote
Old 15th February 2005, 08:52 PM   #6 (permalink)
cokey's Avatar
WOULD COME IN A CRATE TO MY SPEC From Japan !
But even I dont take my own advice..... so I built an HKS 2.8 BILLET CRANK Full stroker kit motor Here at Great expense !!!!
balanced to 12000 revs- In case of a missed gearchange
HKS GT'SS Turbo's- Intake and out pipes etc. Tomei cams blah blah....
Turning japanese is a great song, Vapours --new clear days!
but it will save you thousands !!
Much cheaper than my option.... DOH !
I'll see you lot on the track--- skag's
Just my £11.00000 P's worth !
cokey
Old 16th February 2005, 03:12 PM   #7 (permalink)
GTROC 011
matt j's Avatar
Send a message via AIM to matt j Send a message via MSN to matt j
Originally Posted by NITO
RB28
Top Secret
Single
Nismo Plenum
HKS F-Con V Pro
Hmmm, that gives me an idea!
Snap - maybe?
M.
Old 16th February 2005, 04:46 PM   #8 (permalink)
-C-
The only 'branded' bit I would use would probably an HKS Hi Deck block.
Internals I would go completely custom, custom exhaust manifolds (that wouldnt crack every 5 mins), custom spec turbo's (twins), single TB, custom inlet manifold, proper direct port N2O, pectel T10 ECU.
Then I would go to X-Trac to make me a decent bloody gearbox unlike all the others out there!
"Say no to sheep tuning"
-C- is offline   Reply With Quote
Old 16th February 2005, 09:35 PM   #9 (permalink)
Agree totally.
Tho i think itd just be me n you backed into a corner beating off hordes of angry sheep with sticks tho, lol
Old 16th February 2005, 10:45 PM   #10 (permalink)
Send a message via MSN to skymania Send a message via Yahoo to skymania
Quick question...
(Semi-hijack)
Could someone please explain what exactly a 'Hi Deck block' is?
Sorry for being dumb,
Thanks
skymania is offline   Reply With Quote
Old 17th February 2005, 04:33 PM   #11 (permalink)
gtsm's Avatar
high deck block increases capacity to 2.8 i think looks like big spacer in between
head/head gasket and block think is prety much correct
gtsm is offline   Reply With Quote
Old 17th February 2005, 04:35 PM   #12 (permalink)
gtsm's Avatar
i have been caught out by this as well there is one lurking in this country
already !!
Old 17th February 2005, 07:31 PM   #13 (permalink)
Haribo's Avatar
Send a message via MSN to Haribo
yer its not reali a secret, andy barn's new engine is one, but i think its far more complex than that, or it wouldnt be THE last one, or one of the last ones about..
Haribo is offline   Reply With Quote
Old 17th February 2005, 08:44 PM   #14 (permalink)
Hugh Keir's Avatar
OS Giken 3 litre bottom end to give reasonable off boost torque and 9000 RPM capability.
Between 260° and 280° cams depending on whether you want the emphasis on torque or BHP. Cam lift between 9.5 and 10.8 for road / track, a bit more for drag only.
HKS GT-RS or HKS 2835 or HKS 3037S twins depending on whether you want the emphasis on torque ( 500 + ft lbs ) or power ( 700 to 900 BHP).
A quality tuner to set it up and maintain it.
Motec is my poison for bigger BHP.
You missed one very important category a sequential gearbox linked to the ECU to allow full throttle gearchanges.
It doesn't get much better than that.
Old 17th February 2005, 10:40 PM   #15 (permalink)
Philip's Avatar
Hugh,
What's your reasoning here?
Phil
Philip is offline   Reply With Quote
