Old 24th February 2005, 01:56 PM   #1 (permalink)
Arrow CAMS
Hi do the rb 20 det cams & pulleys fit the GTR haed, i saw hks 256 one for sale at a good price. thanks for imfo. D
drewby is offline   Reply With Quote
Old 24th February 2005, 05:45 PM   #2 (permalink)
SkylineUSA's Avatar
Send a message via AIM to SkylineUSA
Nope, I wish they did.
SkylineUSA is offline   Reply With Quote
Old 24th February 2005, 05:49 PM   #3 (permalink)
JasonO's Avatar
Send a message via ICQ to JasonO Send a message via MSN to JasonO
Are you sure ?
I thought the RB26 stock cam was a favoured swap into the RB20, according to our SDU / SAU freinds.
Expired....
[E&OE.....]
JasonO is offline   Reply With Quote
Old 24th February 2005, 05:56 PM   #4 (permalink)
SkylineUSA's Avatar
Now I am second guessing myself.
Old 24th February 2005, 06:03 PM   #5 (permalink)
SkylineUSA's Avatar
I stand corrected, yes they can be used. There seems to be an issue with the rb26 being a solid, and the rb20 being a hydro.
I'll let someone with a little experiance answer this one.
You can run a mech cam with hydro lifters, but not the other way around.
But, if the lifters can be changed with the cam, you would be golden.
Old 24th February 2005, 06:24 PM   #6 (permalink)
RB211's Avatar
Ah but has the '26 got a pressure oil feed for the lifters??
RB211 is offline   Reply With Quote
Old 24th February 2005, 06:33 PM   #7 (permalink)
JasonO's Avatar
Ahhh, That's it.....it's just the exhaust cam they swap....Sorry
Expired....
[E&OE.....]
Old 24th February 2005, 06:35 PM   #8 (permalink)
SkylineUSA's Avatar
I was told a long time ago that there was an issue, and they could not be swapped. But, like most things, the info that I was given could have been false.
Old 24th February 2005, 06:39 PM   #9 (permalink)
SkylineUSA's Avatar
Jason,
Why just the exhaust?
Old 24th February 2005, 07:14 PM   #10 (permalink)
JasonO's Avatar
Arrrgh.....
This thread on SAU says that the RB26 cams are a straight swap into the RB20, with some minimalist gains.
The RB20 doesn't have the VTC that the RB25 has, and I'm mixing them all up.....
Expired....
[E&OE.....]
Old 24th February 2005, 07:21 PM   #11 (permalink)
SkylineUSA's Avatar
That link is not working for me, for some reason.
But Drewby wants to do it the other way, so I am pretty sure that will not work.
Old 24th February 2005, 07:49 PM   #12 (permalink)
RB211's Avatar
That's what I was trying to say, there is no pressure oil feed in a'26 to make the hydraulic lash adjusters work. The RB20 cams (unless specials) are ground to suit hydraulic lifters, not solids which have different ramp profiles. You can use Hydraulic lifters under solid cams, but not vice versa.
Jason, I think if you laser drill an oilway in the nose of a GT-R cam, you could probably use the vvt - not 100% on it tho?
