Old 20th April 2005, 12:34 PM   #1 (permalink)
763paf's Avatar
standard boost?
what is the standard boost for a R32 gtr running standard turbos?
( i did a search but only came up with modded boost specs.)
I dont want to damage the engine by blowing ceramics into the baby...
i am running 1.0 at mo.
Is this ok? Safe ?
763paf is offline   Reply With Quote
Old 20th April 2005, 04:09 PM   #2 (permalink)
I think the standard boost is aroun 0.7bar
As far as I know 1 Bar is the recommended max boost for standard turbos.
Keith
ko_racer is offline   Reply With Quote
Old 21st April 2005, 01:16 PM   #3 (permalink)
763paf's Avatar
thanks keith, checked it this morning. actually spiking at about .8. so not far off.
cheers
Old 21st April 2005, 01:58 PM   #4 (permalink)
Kim2770's Avatar
Send a message via MSN to Kim2770
blowing ceramics into the engine... isn't it the turbine (exhaust) wheel on the turboes that are made from ceramic???
Kim2770 is offline   Reply With Quote
Old 21st April 2005, 03:03 PM   #5 (permalink)
Piggaz's Avatar
Send a message via ICQ to Piggaz Send a message via MSN to Piggaz
R32 - 0.78 kg/cm^2 (0.765 bar, 11.1psi)
R33 - 0.84 kg/cm^2 (0.824 bar, 12.0psi)
R34 - 0.93 kg/cm^2 (0.912 bar, 13.2psi)
Piggaz is offline   Reply With Quote
Old 29th April 2005, 07:24 PM   #6 (permalink)
Silver R33 GTR's Avatar
For the R33 is that the standard boost or the peak you should run on stock tubbies? Only asking beacuse mine peaks at about 1.08kg/cm^2 without mods, 'well basically'.
robin.
Silver R33 GTR is offline   Reply With Quote
Old 30th April 2005, 03:36 AM   #7 (permalink)
Piggaz's Avatar
That's the numbers someone has quoted on here in a earlier thread. Just one of them things i saved and put in the *GTR INFO* folder hehe.
