| View Poll Results: GTR Gearboxes.... | |||
| Stock box fine and serves its purpose well, no problems yet thanks.. |
149 | 43.19% |
| Stock box was fine but now causing some concern whilst changing.. |
80 | 23.19% |
| Stock box doing my head in now and needs changed asap! |
10 | 2.90% |
| Stock box let me down and now on 2nd.. 3rd... 4th...replacement.. |
21 | 6.09% |
| Rebuilt stock box and very happy now thanks! |
18 | 5.22% |
| Killed rebuilt box and need a really expensive one.. HKS..O/S.. |
9 | 2.61% |
| I have a really expensive box.. and am a smug b**tard thanks ;-)) |
37 | 10.72% |
| None of the above |
25 | 7.25% |
| Multiple Choice Poll. Voters: 345. You may not vote on this poll | |||
#31 (permalink) |
lots of Aussie GTR's are using REDLINE lightweight shockproof - including me
good stuff, and something I will continue to use.I suggest you also use a suction pump to get the oil in - much easier..... |
#32 (permalink) | |
#33 (permalink) | |
Mate I am just another GT-R owner that luckily found the REDLINE stuff before wasting money on a gearbox rebuild!!!!
if you are interested there is plenty of good info in the Aussie http://www.skylinesaustralia.com site on redline.... is expensive as! (about 50 pounds here) but worth it!!! Quote:
#35 (permalink) |
I think it does, there are R32s in japan with R34 boxes so no reason not to fit, conversion cost, no idea but guessing an R34 box alone would be worth a couple of k.
As for reliability, do a search, lots have been written & i think the consensus is that the 6speed is no stronger than the 5, I use to have an r33 (0.8bar chip)which started to baulk between 4 & 5 at approx 50000 motorway miles & driven in a restrained fashion. I'll stick with 5 & factor in gearbox rebuild as a wear & tear part. |
#37 (permalink) |
I seemed to remember Abbey M/S talking about rebuilding the 5 speed with uprated Nissan? parts, as for prices, don't know for sure but think it could be around a £1000+ mark, best to phone a few reputable places & get prices, update on the 6 speed is the box is around £2-3000 + fitting & u'll need a new propshaft? as the gearbox is slightly longer than the 5 speed.
#40 (permalink) |
At some point, towards the end of R33 GTR production, Nissan uprated 4th / 5th gear assembly including syncro rings.
Any rebuild of the std box should now include these more robust parts, as original parts are no longer available. The synco rings are apparently stronger as is 4th&5th assembly. Rebuild cost from specialist circa £1800........ |
#42 (permalink) |
GTROC Member 489
Richard bell put in the new Redline Heavy Shockproof oil in the gearbox for me when he put the engine back in. Before then the gear change from 4th to 5th was crunching really badly, even when pausing in neutral for half a second. There was just an awefull sounding crrrunnnch
Now it's perfect, even on fast changes and the box is super slick from cold. Two or three people advised me to try the Shockproof oil, but I was scepticle. I mean, how can just a different oil help a weak synchro ring? Go on, try it - dam sight cheaper than a gearbox rebuild ![]()
Geoff - Rising Sun Performance tuned R34GTT RB30with a T04Z - 675bhp 574lbs all through the rear wheels........... |
#43 (permalink) |
ADMINISTRATOR
can anybody advise me how much redline i would need to change the gearbox oil? And wether lightweight or heavyweight is best for a stage 1 r33 gtr?
thanks in advance mook
WANTED - TEIN FLEX for R33 GTR FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
#44 (permalink) | |
Do it right or don't do it at all. "You're a pack of a**holes!" - Jim Richards 1992. スカイライン69 UK |
#45 (permalink) | |
