View Poll Results: GTR Gearboxes....
Stock box fine and serves its purpose well, no problems yet thanks.. 149 43.19%
Stock box was fine but now causing some concern whilst changing.. 80 23.19%
Stock box doing my head in now and needs changed asap! 10 2.90%
Stock box let me down and now on 2nd.. 3rd... 4th...replacement.. 21 6.09%
Rebuilt stock box and very happy now thanks! 18 5.22%
Killed rebuilt box and need a really expensive one.. HKS..O/S.. 9 2.61%
I have a really expensive box.. and am a smug b**tard thanks ;-)) 37 10.72%
None of the above 25 7.25%
Multiple Choice Poll. Voters: 345. You may not vote on this poll
Old 27th February 2006, 07:43 PM   #61 (permalink)
kenan's Avatar
Send a message via MSN to kenan
Second
In my 205 I can pull away in third no probs
kenan is offline   Reply With Quote
Old 2nd March 2006, 12:45 PM   #62 (permalink)
lol, i had to get my synchro replaced a few weeks back on my stage one R33 GTR. 3rd to 4th was crunching on high rpm change ups (weird huh?) so sent it to get fixed.
At the same time i ordered some Redline Shockproof Lightweight box oil to put in.
the box has been problem free for approx and super smooth for the 1k miles ive done since. I too find the car doesnt like being put into first when cold but i find if i engage reverse before trying first it goes in problem free
koopa is offline   Reply With Quote
Old 10th March 2006, 06:07 PM   #63 (permalink)
bonez59's Avatar
pull away in second??? good night clutch.
NURBURGRING in 7,52s!!!!!!!
AEM
R32 GTR.
JE Pistons
T78
3 large fuel pumps should do the JOB
202.8mph on GPS good, melting piston at the same time not good
MARLON MOTORSPORT
bonez59 is offline   Reply With Quote
Old 10th December 2006, 04:36 AM   #64 (permalink)
meathead's Avatar
Has anyone tried redline MT90 which I would like to try in a r33 vspec gearbox with low Ks The american website reckons lightwieght shockproof is for worn out boxes and is not real good on newer synchros.
They have a lsd gear oil redline 75W90 GL5+ for both diffs which is what the manual specifies almost. (85W90 front and 80W90 rear)
Redline is by all accounts the good gear any comments on the above would be appreciated
meathead is offline   Reply With Quote
Old 11th December 2006, 11:45 AM   #65 (permalink)
mr circuit's Avatar
I love my ppg dog box cant go wrong, Wish i had of done this after the first gearbox failure and not the third.
mr circuit is offline   Reply With Quote
Old 12th December 2006, 08:37 AM   #66 (permalink)
3rd to 4th on a 97 V Spec a bit notchy but I can live with it. Had a GTST which was the same so I put some Lucas Additive in it which is advertisied as a revitaliser, seemed to cure it it but it was a bit thick and you had to sueeze the bottle like beggery to get it in and at £36 a bottle it wasn't cheap.
bww8 is offline   Reply With Quote
Old 12th December 2006, 09:02 AM   #67 (permalink)
kismetcapitan's Avatar
I've got a tricky 4th gear which I've learned to completely avoid crunching by: from 3rd to 4th, granny-shifting, or going into neutral, letting go briefly of the shifter, then snicking it into 4th. I rarely crunch 4th, even on all out pulls.
From 5th to 4th, a mild double-clutch does the trick. blip the throttle a little (not too much or it'll again crunch), and slide it in. I cannot shift from 5th to 4th normally, unless I wait about five seconds in neutral.
Am using HKS transmission oil, which takes a bit of warming up. But combined with the Nismo solid shifter, I like the feel of my transmission very much.
Old 13th December 2006, 10:17 AM   #68 (permalink)
Any tried putting in some molyslip? (in the tube).
RamRod is offline   Reply With Quote
Old 13th December 2006, 06:05 PM   #69 (permalink)
GTRBrian's Avatar
does anybody know how much used trannys for r32s are selling for
GTRBrian is offline   Reply With Quote
Old 29th December 2006, 03:57 AM   #70 (permalink)
Dohc's Avatar
Send a message via MSN to Dohc
mine needs new synchrome for 4th gear.
otherwise...its very good
Dohc is offline   Reply With Quote
Old 4th January 2007, 09:43 PM   #71 (permalink)
4ndy's Avatar
I have 124k on the clock and the only problem I have is 4th to 5th at full chat grinds so have to let the revs drop a litle before i try
Andy
4ndy is offline   Reply With Quote
Old 23rd January 2007, 11:49 PM   #72 (permalink)
Send a message via MSN to Mashrock
Have 34gtr box into my 32 gtr.
i love it!
broke 1 standard ones, and trust dog box was not in good condition when i bought car from japan
Mashrock is offline   Reply With Quote
Old 7th February 2007, 04:56 PM   #73 (permalink)
Individualist's Avatar
Send a message via MSN to Individualist
Redline HWS oil, the way to go........no problems at all in any gear
Individualist is offline   Reply With Quote
Old 4th March 2007, 12:43 AM   #74 (permalink)
gavman's Avatar
Originally Posted by GTR-Zilla View Post
no one double de clutches these days.. you mean heel and toe?
to correctly heel'n'toe you must double declutch
when you blip the throttle you should be in neutral, clutch released
gavman is offline   Reply With Quote
Old 16th March 2007, 11:59 PM   #75 (permalink)
there is no point being in neutral to double clutch
icydude is offline   Reply With Quote
