View Poll Results: GTR Gearboxes....
Stock box fine and serves its purpose well, no problems yet thanks.. 149 43.19%
Stock box was fine but now causing some concern whilst changing.. 80 23.19%
Stock box doing my head in now and needs changed asap! 10 2.90%
Stock box let me down and now on 2nd.. 3rd... 4th...replacement.. 21 6.09%
Rebuilt stock box and very happy now thanks! 18 5.22%
Killed rebuilt box and need a really expensive one.. HKS..O/S.. 9 2.61%
I have a really expensive box.. and am a smug b**tard thanks ;-)) 37 10.72%
None of the above 25 7.25%
Multiple Choice Poll. Voters: 345. You may not vote on this poll
Old 17th March 2007, 12:15 AM   #76 (permalink)
have a slight crunch when changing at high reve from 4th to 5th but nowt major, gonna try some heavy shockproof oil, how much will i need?
brianbunning is offline   Reply With Quote
Old 22nd March 2007, 08:44 AM   #77 (permalink)
Bucky's Avatar
Originally Posted by gavman View Post
to correctly heel'n'toe you must double declutch
when you blip the throttle you should be in neutral, clutch released
You must have some long and weird shapped feet to be able to blip the throttle whilst the same foot is on the clutch pedal.
Bucky is offline   Reply With Quote
Old 4th April 2007, 04:54 AM   #78 (permalink)
nozza1's Avatar
6 speed getrag
Owned my r43 gtr vspec for about a year now and lm really unhappy with the gearbox. Its fine when cold but when it heats up it has a progressive whining noise and keeps on jumping out of second. Didnt crunch in the beginning but has now a few times. Want to rebuld the box but nobody wants t touch it locally. Managed to find a company in milton keynes known as compotition transmissions, web sight Gearboxman - home. he has said he can do it but he might have to source the parts from other gearboxes. ( nissan do not provide parts for gearbox) Im abit unsure and was wondering if anyone has had the same problems with the 6 speed getrag and has anyone heard of the gearboxman. please could somone advise and point me in the right direction. thanxs
nozza1 is offline   Reply With Quote
Old 4th April 2007, 08:56 AM   #79 (permalink)
Floyd's Avatar
I remember reading somewhere that the Toyota 6speed R160 getrag box is the same as the R34 getrag, perhaps there's someone who can confirm this, or tell me I'm wrong?
Floyd is offline   Reply With Quote
Old 4th April 2007, 02:15 PM   #80 (permalink)
gavman's Avatar
Originally Posted by icydude View Post
there is no point being in neutral to double clutch
you have to be in neutral to be able to take your foot off the clutch
you have to take your foot off the clutch WHILST blipping the throttle, in order to match transmission speed to the gear you are about to drop into
to explain:
in fourth gear, approaching third gear corner
begin braking (right foot)
clutch in (left foot), select neutral, still braking (right foot)
release clutch (left foot), transmission now in neutral, still braking (right foot)
now continue braking with inside of right foot and blip the throttle with the outside of the same foot (heel'n'toeing)
clutch in (left), into gear, release clutch as revs match road speed (still braking)
release brakes, turn in
gav
gavman is offline   Reply With Quote
Old 26th July 2007, 05:45 PM   #81 (permalink)
GTR RGT's Avatar
Send a message via MSN to GTR RGT
What weight (w) is Redlines heavy shockproof?
And am I right in saying I need 4.1 litres to feel my gear box?
1st and second hate me
GTR RGT is offline   Reply With Quote
Old 26th July 2007, 06:04 PM   #82 (permalink)
Go to Turbobits for best prices on Redline
myline is offline   Reply With Quote
Old 10th August 2007, 08:54 PM   #83 (permalink)
ru'
ru''s Avatar
Surely to double declutch you must double declutch.
Heel and toe-ing is (imho) different; blipping the throttle on down changes to make it smoother etc. and doesn't require double declutching. Of course you can (do) blip the throttle when double declutching.
Does that make any sense?
Old 11th August 2007, 08:12 AM   #84 (permalink)
Bucky's Avatar
Why the **** do you want to double de-clutch a box with syncro's??
Do you's know what yous are talking about?? You only double de-clutch a crash box or a very ****ed standard box.
Old 11th August 2007, 09:21 AM   #85 (permalink)
ru'
ru''s Avatar
I've never DDC (life's too short), but I often H&T. Having said that I've never driven a car without synchros.
Old 12th August 2007, 04:53 PM   #86 (permalink)
gavman's Avatar
i was taught (incorrectly) that i needn't double declutch when heel'n'toeing
first time i had circuit instruction the instructor kept peering over to see what my left foot (wasn't) doing as i blipped the throttle while on the brakes
it's not just the engine, but the entire drivetrain needs to be synchronised
try dropping down to first gear without doing it!
it is one of those 'masonic handshake' driving techniques that will always give you an advantage over someone not doing it
it just keeps the car smooth whilst braking, and then helps you make a smooth, clean transition to full throttle, without the car dancing about, and means the engine is on cam ready to pull you through the corner
in a nutshell, it makes you quicker
that's why in-car footage of rally drivers often shows their feet dancing across all three pedals
Old 14th August 2007, 07:48 PM   #87 (permalink)
rb30 710bhp
rockabilly's Avatar
Send a message via Yahoo to rockabilly
very true gavman. too give you guys an idea of how effective double declutch is, for example if you wanted it would be possible to be doing 80 mph in 4th and by the above method and a very heavy rev in between you could select 2nd with no crunching whatsoever. now i know the box would blow up if you let the clutch out, but if you tried the same thing but this time just pressed the clutch once and then tried to select 2nd you would hear the most almighty grinding noise ever. thats the principle reason for the above. you bring the next gear down upto the correct revs so that when you release the clutch the revs are already at the right speed..bernie
fancy the south of france.
http://st-tropez.mysite.orange.co.uk/
Old 14th August 2007, 07:50 PM   #88 (permalink)
Send a message via ICQ to M SKinner Send a message via MSN to M SKinner
Some people dont like wearing their synchros out, and like a faster gearchange
M SKinner is offline   Reply With Quote
Old 19th August 2007, 07:34 PM   #89 (permalink)
TidyTobes's Avatar
Send a message via MSN to TidyTobes
Just 3rd to 4th on mine, will get round to it some time??
TidyTobes is offline   Reply With Quote
Old 27th September 2007, 11:41 PM   #90 (permalink)
GT-R Glenn's Avatar
OS Giken 1st to 5th
Love it.
I will most likely change my diffs to gts4's.
GT-R Glenn is online now   Reply With Quote
