Id always use somthing along the lines of 10/60 for a hard tuned hard used turbo car.
Always have, always will, works spot on. The amount of heat and grief a turbo car gets, nothing else ive tried seems to work as well. I got my personal stash of 10/60 Castrol RS here waiting for my car to be finished. Well ****ed off that these days only widely available RS is the homo 0/40, used to be able to get 10/60 direct from any Halfords, but luckily I horded some, lol. LOL@5/40 or 10/40 on a hard driven tuned turbo car, not a chance, especially not one without mega tight tollerances, that oil is standard n/a car type oil in my eyes. I can hear the rattles from the engine and rebuild bills being printed already, lol. |
Believe me, sae 60 is too thick.
Sae 50 is as thick as I would go, you're causing friction, heat and wear let alone wasting power dragging a thick oil around. Even worse, if your oil temps are not excessive then this oil is too thick at high temps for an engine that is happy between 10 and 14cst viscosity. I've posted all the data before but I guess it's not been read. The actual recommended viscosities (in the handbooks) are 5w-30, 5w-40, 10w-30, 10w-40. Cheers Simon
oilmans website : www.opieoils.co.uk/ e-mail : oilman@opieoils.co.uk tel : 01209 215164
I'm with Simon and Nissan here, I've been using 10W40 for over 3 years now apart from the day my ends went at Brands when I'd put 10W50 in the week before. Not saying that was the cause but I'm now certain it contributed towards the failure....
I've used 15w60 before, the oil pressure won't go below 4-5 psi, and constantly at 8 psi at full throttle. The engine felt noticably less responsive, especially when the oil was cold, when the psi's won't drop below 6 under any throttle condition. My rocker seal blew because of it (well, it happened at the same time, the assumption thus remains at such).
I used to use 15w50 (which is what Nismo recommends), but using Redline 10w40 recently. Has been running perfectly. Will be switching back to 15w50 when I get the new turbos, but no more than that. |
This engine was designed in stock form to run on sae 30 or 40.
Ok, there is an argument in cases of modifications and track use to use an sae 50 but as I've said before, sae 60 is way off spec. The consequences of using an oil that's too thick are: More engine wear More heat/friction Lower BHP Higher Fuel consumption Too much oil pressure Pump cavitation leading to starvation Don't risk it as it's not worth the cost of a rebuild! Cheers Simon
#13 (permalink) |
What is the reasoning when the recommended oil is in fact sae 30 or 40.
Just seems the old argument of "thicker is better" which is not the case when the car only needs 14cst at 100degC. sae 60 is 24cst at 100degC and therefore excessive even if the car is modded. Unless oil temps are a problem, just step up the quality - Not the viscosity! Cheers Simon
#14 (permalink) |
Location: somewhere over the rainbow ( not far from Jeff )
I know what you are saying Simon and thinner oils are very good in Winter as they get round the engine faster ,in fact I have used 0-40 mobile 1 before and never had a problem .Dont know if anyone wants to compare but my GTR 34 running on 10-60 at normal sprited driving sits at around 96 oill temp when booted hard and comes down to about 90 when on a long medium speed steady run ,dont know what anyone elses goes to or who has had there oil temp up quite high .Another thing has anyone really noticed much differance in oil temps with differant grades of oil ,Intersting to find out .
#15 (permalink) |
Banned
Im with oilman on this, you cant simply use a 10w60 oil just for the sake of it cus x tuner has said its better than y tuner.. nissan has recommended a 30 or 40 weight, then pushing that to a 60 is goind a bit OTT. I guess a good double ester 10w50 would be ok for a hard pushed driven car.
