Old 24th June 2005, 05:06 PM   #1 (permalink)
trackday addict's Avatar
Smile AP Calipers ?
Has anyone fitted AP 6 pots & discs before & was there a noticeable improvement over the Brembo 4 pot & disc set up ??
if so - anyone got a part number for the AP's & what's the max disc size ?
John
Year 4 of the 5 year journey starts March 09 ........
Europes 1st Ever 7 sec skyline
7.7537s @ 175.64mph backed up
Europes Fastest Jap car in 2008
- www.projectgtst.com
trackday addict is online now   Reply With Quote
Old 24th June 2005, 05:24 PM   #2 (permalink)
ap brakes
got ap 6 pot and disc on my 34, not that much difference than those on my 33,however, the discs are slightly worn,my be better with fresh discs which are due soon
Will
WILL SMITH is offline   Reply With Quote
Old 24th June 2005, 07:33 PM   #3 (permalink)
www.ap-racing.com - have a look under road kits......
Old 24th June 2005, 10:19 PM   #4 (permalink)
What do you think ?
This were the set I was looking at - reasonably straight bolt on ??
Brand new AP Racing Water Cooled 4 Piston calipers. 2 piece aluminium alloy body, radial mount, Liquid cooled, 'R' clip quick release pad retainer. Differential bores, aluminium alloy pistons
Differental bore pistons 25.4mm x 2, 31.8mm x 2
Maximum disc thickness 32mm
Radial mount centre 130mm
Mounting holes 10.2mm
Water cooled
Part number cp-4296
Maximum disc diameter 304mm
Comes with cross drilled discs
25mm thick
Cross drilled
299mm Diameter
12 Mount hole design
Disc p.c.d 7"
Old 25th June 2005, 11:43 AM   #5 (permalink)
Those disks are a touch small, diameter and thickness. The R33 kit is 343mm and 32mm thick.
