Thread: STOPTECH brakes
Old 30th November 2005, 03:56 PM   #2 (permalink)
sleepyfox
sleepyfox's Avatar
So presumably this means that you need a balanced set of front and rear caliper upgrades so that the increase in pad area * hub radius and remains constant at both front and back?
Would you normally fit a brake bias valve also?
What would this cost for an R32 with 330mm 4-pot fronts? (disks*4, calipers*4, bells*4, brackets*4, braided lines*4, ATE Super Blue + fitting)
Fox
sleepyfox is offline   Reply With Quote
