Old 4th July 2005, 03:31 PM   #1 (permalink)
Turbo Lag
Just had my stock turbo rebuilt with steel internals and a 360 thrust bearing etc. and whilst it's performing pretty well I seem to have a strange problem with lag. Basically the turbo begins spooling pretty quick but then it seems to gain a lot more power at 6000rpm and of course there's little room for this to be used before hitting the limiter.
I've tried all manner of different settings on the Profec B (including increasing the gain) but this has made no difference. I've also adjusted the actuator rod so there is a small amount of pretension and again no difference.
Just wondered if anyone had any other ideas what might cause this?
Cheers!
rculley is offline   Reply With Quote
Old 6th July 2005, 03:03 PM   #2 (permalink)
Is it a gtst? if so I had my unit rebuilt, Mine is a bit slower on the spool up, but when I get to about 5500rpm it tends to hold back and at 6000rpm it goes well again. might not be the same problem but the people I go to said it may be fuel starvation, so bigger injectors and fuel pump. Dont hold me to it but mines always done this since I started tuning it. hope this helps
skylineman is offline   Reply With Quote
