Old 12th July 2005, 11:50 AM   #1 (permalink)
cleaning an AFM hotwire - WD40 etc ok to use?
Not for the skyline but another car I own with a hotwire afm. I think its covered in oil and I want to clean it to try and sort an occasional dodgy high idle.
not sure what the hotwire is made of or if covering it in brake cleaner or WD40 would be fatal.
Anyone got any idvice?
Thanks
Martin
Old 12th July 2005, 12:05 PM   #2 (permalink)
Pikey's Avatar
Carb cleaner is the stuff to use IIRC. Although I might be wrong.
Old 12th July 2005, 02:01 PM   #3 (permalink)
NigelR32's Avatar
Martin,
A GENTLE application of carb cleaner will do the trick. Dont be tempted to try doing it on the car either. Take the AFM off, and spray gently over the wire, so the excess runs straight out through the body.
Your high idle is probably due to a sticky idle valve. Again, clean with carb cleaner.
Regards
Nigel...........GTROC Member
Now on '32GTR No.3
NigelR32 is offline   Reply With Quote
Old 12th July 2005, 02:33 PM   #4 (permalink)
Thanks chaps. The thing is, the hot wore appears to be connected onto the throttle meaning removing it would be a swine. I can get good access to it and just after it is the butterfly meaning nothing will get past that so i could just mop up any residue after.
I dont have any carb cleaner - nor any carbs for that matter so it would be a shame to have to buy some just for this. WOuld any alternative b ok - such as wd40 - brake cleaner / engine degreasant ie gunk?
or does it have to be that stuff?
cheers for the info so far
cheers
mart
Old 12th July 2005, 02:36 PM   #5 (permalink)
ADMINISTRATOR
Mookistar's Avatar
only use carb cleaner. wd40 is NOT the same.
for the damage you could do, a couple of quid on a can of carb cleaner is no expense.
in my punto days, we just sprayed the AFM with carb cleaner, engine running!
lol
mook
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN'
SKYLINE FAQ'S!
Old 12th July 2005, 03:20 PM   #6 (permalink)
As said above, carb cleaner is the thing to use, definitely not WD40.
I don't understand what you are saying about the hot wire being connected onto the throttle. Unless you're using some kind of blow through system, the AFMs are located just after the air filter/s. I would definitely take them off to clean them. They're pretty straighforward to remove.
lynchy is offline   Reply With Quote
Old 12th July 2005, 05:03 PM   #7 (permalink)
Banned
GTR-Zilla's Avatar
can you spray direcly at the hotwire or will that break it? looks so fragile...
GTR-Zilla is offline   Reply With Quote
Old 12th July 2005, 07:33 PM   #8 (permalink)
its not for the skyline. its a high power application.... a pug 306 cabriolet....
I held off doing it after work suspecting someone would say dont use wd etc etc
Think I will pop down halfrauds and get some carb cleaner. Will do the idle control valve too then.
cheers for the info
