Thread: Tyres
Old 12th December 2005, 04:36 PM   #148 (permalink)
kenan
kenan's Avatar
Send a message via MSN to kenan
You can get cheap camber kits from a company in Aus called Whiteline. Put a set on the rear of my car and sorted the camber problem (normally due to lowering the car). The one I got consisted of an eccentric bush giving the correct camber adjustment. I believe Abbey are now stocking these (since seeing mine) and would recommend getting them to set-up the car geometry as mine was a different car afterwards.
kenan is offline   Reply With Quote
