Old 12th December 2005, 07:48 PM   #1 (permalink)
Tenacity
Tenacity's Avatar
Send a message via MSN to Tenacity
Can you help me ?
hi guys ,
i have an r33 gts 25t 95 model caR WHICH generally is in superb condition .
the reason i am asking you for your help is that for the past 7 weeks i have had a fault with my car and 3 garages have failed to rectify it .
my car is idleing erraticallly and cutting out intermittently , while also appears to be using more fuel than usual .
it is also shuddering when applying acceleration and generally is running rough .
ecu and all other items have been checked as usual and its saying all systems clear , lol .
its had a new idle control valve fitted and tps sorted , as well as lambda checks and live data tests on oxy sensor and afm.
its even had an engine treatment applied in case the valves are at fault through clogging .
nothing seems to have sorted the problem, i am at my wits end , i just want my car running as normal , please can you advise as to where i can take it to sort this problem out once and for all .
its fitted with an hks spf ind kit and the hks ssqv BOV .
THIS IS RUNNIN FINE IM TOLD .
PLEASE HELP ,
THANKS ,
MATTY [ e/mail = mattysmith@blueyonder.co.uk
http://img493.imageshack.us/img493/3...49810023bi.jpg
Tenacity is offline   Reply With Quote
