Old 15th July 2005, 07:34 AM   #1 (permalink)
Send a message via AIM to chopper
Brake fluid
Which is the best type to get for the GTR 32 ? Silicone based, dot number etc ? Running vented fronts, redstuffpads and braided lines - ABS is active
Cheers - Mike
chopper is offline   Reply With Quote
Old 15th July 2005, 07:56 AM   #2 (permalink)
I would use DOT 5.1 silicone based fluid.
hybrid is offline   Reply With Quote
Old 15th July 2005, 08:00 AM   #3 (permalink)
Thanks
Old 15th July 2005, 08:26 AM   #4 (permalink)
dont use silcone fluid it doesnt mix with other fluid and your car wasn't designed for it.
4 or 5.1 are OK as they are not silcone based. if drifting is hard on the brakes you'd want a high temp dot 4 fluid - something like MOTUL RBF600 or Castrol SRF with a +300c boiling point
5 is silcone based and not what you want.
Old 15th July 2005, 09:47 AM   #5 (permalink)
5.1 does have a high silicone content...doesnt it?
Old 15th July 2005, 10:26 AM   #6 (permalink)
Sorry my mistake, 5.1 non silicone based, just done my homework.lol
Old 15th July 2005, 04:00 PM   #7 (permalink)
oilman's Avatar
We recomend the RBF600 dot4 for performance use as it has a very high boiling point.
Tyhe dot5.1 tends to be a long life fluid, will last longer under normall use but will boil quicker then the racing dot4 when driven hard.
Simon.
tel : 01209 215164
Old 28th July 2005, 01:34 PM   #8 (permalink)
240K-GT's Avatar
Send a message via MSN to 240K-GT Send a message via Yahoo to 240K-GT
Is there anyway you can flush old fluid out of brakes / clutch systems?
Just reading the pdf for RBF600 and says they recomend not to mix it with anything. Would running some meths and alowing to dry be ok, or would that damage stuff?
Will
240K-GT is offline   Reply With Quote
Old 28th July 2005, 04:49 PM   #9 (permalink)
stew-s's Avatar
Send a message via MSN to stew-s
dot5.1 fluids tend to esther based.
probably the best brake fluid in the world is castrol SRF. and its not cheap. ATE super blue is another good one.
stew-s is offline   Reply With Quote
