R32 GT-R Viscous fan *urgent help needed*
Hi,
Is the Viscous fan the same on other nissan cars? Like 200sx S13, S14? Mine is loose/gaping. And it sounds funny. Im scared that it will be released in the engine bay So please tell me, Are the viscous fans the same on other Nissan cars? THat would make it easier to find one around here in Sweden. ThanX!! Johnny Norberg |
A few years back a friend of mine had one on an E30 325i sport where the bimetallic strip failed and the fan was permanently on. The water pump couldn't take the thrust loading and the impeller almost machined its way out of the housing.
My old one managed to put a nice arc shape in my radiator once under full throttle. Turns out the plastic was cracked, and the fan became unbalanced.
So definitely check for cracks in the fan. And look at how much the fan moves back and forth in the engine bay when you play with the throttle. |
#6 (permalink) | |
Replace it quick. |
#8 (permalink) | |
you couls also ditch the fan completely, and fit an electric kenlowe unit or similar.
The kenlowe ones have their own adjustable thermostatic switch, so you can adjust at what temp the fan turns on & off. By ditching the viscous unit you are also gonna be reducing the rotating mass on the front of the engine, which can only be a good thing |
Viscous couplings are designed to meet three main criteria, faster engine warm up (in pursuit of emissions control and fuel economy), less fan noise, and less power drain on the engine (better economy and performance from a given engine size and efficiency). The axial thrust capabilities of even the most basic ball bearings of the size found in a typical water pump will laugh at a fans thrust, even when driven at full engine speed or above.
Noise was probably the first reason an engine driven fan was given attention. The old flexible bladed fans came first, then the French favoured electromagnetic clutches on Peugeots and others, then the viscous coupling latterly found favour for cost, simplicity and reliability An electric motor driven fan would have to have a motor the size of an alternator, with a massive current draw to shift similar volumes of air to that of the equivalent sized engine driven fan. The very small frontal aperture areas of modern cars means the cooling fan is very important as ram effect is nothing like that of older cars with their relatively massive grille apertures, the smaller openings being in pursuit of less drag (better MPG and top speed). Very few front engined cars solely use an electrically driven cooling fan, I think you will find. |
#13 (permalink) | |
#14 (permalink) |
Banned
RK uses electric fans on his cars, and even sells a kit, speaking to him hes never had any problems with them. I believe the electric fan is a good replacemnt, lots of sports cars, with v8's etc seem happy with electric fans...
