View Poll Results: Aftermarket or OEM
OEM 44 38.26%
Aftermarket 71 61.74%
Voters: 115. You may not vote on this poll
Old 16th July 2005, 02:11 AM   #1 (permalink)
aki
aki's Avatar
aftermarket cambelt
When i get my car i'm planning to change the cambelt along with service. Now i've noticed that a lot of guys use aftermarket cambelts, such as tomie. Are the OEM cambelts not very reliable, or are aftermarket belts just so much better? there seems to be a large difference in price and i just want to know if the extra price is justified and also to gauge some opinion from people.
aki is offline   Reply With Quote
Old 16th July 2005, 08:58 AM   #2 (permalink)
NikWilson's Avatar
Got a Nismo one on mine from Middlehurst, far better quality than the standard one and after 3000 miles, has not streached at all.
Nik
NikWilson is offline   Reply With Quote
Old 16th July 2005, 09:59 AM   #3 (permalink)
Dave_R1001's Avatar
Im waiting to collect my car too... I bought a Tomei Kevlar item to be put on.
Its only £100 so thought it worth it for the peace of mind.
Dave_R1001 is offline   Reply With Quote
Old 16th July 2005, 10:20 AM   #4 (permalink)
tweenierob's Avatar
Power enteprise for me.. to go with my tomei pullies and clear cover.. no other reason
Rob
599hp R35 Gtr www.trracing.co.uk
T62 Going back on for track WTF!! :D
Addicted to Snett!! Roll on the 24th of jan £99 rocks!
tweenierob is online now   Reply With Quote
Old 16th July 2005, 10:38 AM   #5 (permalink)
R32 Combat's Avatar
Personally, I can't see that a STD cambelt would stretch enough for it to be a problem. IMHO only fit an uprated one if you run steep cams @ very high revs..
Old 16th July 2005, 12:13 PM   #6 (permalink)
aki
aki's Avatar
That was my initial thought as well, TBH I'm still undecided as to which to go for. Where is the cheapest place to get an aftermarket belt, if there isn't as much difference in price as i originally thought then i may just get an afetrmarket one.
Old 16th July 2005, 01:21 PM   #7 (permalink)
R32 Combat's Avatar
I'd go to nissan, dunno how much though, £30 maybe.
Old 16th July 2005, 01:43 PM   #8 (permalink)
NISFAN's Avatar
Buy one with Kevlar in it ........it's good for my companies share price
Old 28th July 2005, 12:47 PM   #9 (permalink)
Pikey's Avatar
£40 for a standard one, £100 for a GReddy one. I got the GReddy one, but on reflection I dont really know why lol
Old 28th July 2005, 12:56 PM   #10 (permalink)
Nik
What bloody cambelt would stretch after 3k of road use and how would you have noticed
Old 28th July 2005, 09:03 PM   #11 (permalink)
Pulse D's Avatar
I bought a Greddy Kevlar belt . . .
Also changed the pulleys to Greddy adjustable one's & fitted new tensioners for good measure! It all looked sooo blue and pretty, so i bought a clear Greddy cam belt cover so my girlfriend could see what i'd spent my money on!
M
P.S My car has done 50,000 miles.
Pulse D is offline   Reply With Quote
Old 10th August 2005, 05:22 PM   #12 (permalink)
Snathe's Avatar
An OE Nissan belt is fine..... I'd only fit an aftermarket belt if the engine was fitted with lairy cams and / or had a higher rev limit.
Also, the tensioner and guide roller should be changed at the same time as the belt
Snathe is offline   Reply With Quote
Old 10th August 2005, 10:29 PM   #13 (permalink)
Alex j B's Avatar
I got a Greddy one, was only about £10 more than a Nissan one, so thought it was silly not to! (Genuine Nissan cambelts are just over £40 if I remember right).
Alex B
Old 10th August 2005, 11:25 PM   #14 (permalink)
NikWilson's Avatar
My point which I did not think need clarifying was:
That the cam belt was fitted with a new tensioner and to the correct tension accoring to my R34 GTR workshop manual. The car was used for about 3000 road miles including 2 track days. I wanted to replace my cams to stage 1's after all this and so decided to remove the belt in anticipation of the new cams turning up . To see how the belt had lasted, I check the tension again BEFORE removing the belt, and it was exctly as I had fitted it a few months before. I guess it could be argued that had the tension changed in the interim, it could also be down to wear in the belt tensioner?
Just my opinion based on my car.
Nik
Old 1st January 2006, 03:54 PM   #15 (permalink)
Marky_GTSt's Avatar
From what I can tell the belt is under most stress at idle and cranking speeds (Im guessing less inertia on the cams)
I say this cos allmost evey engine I have worked on with a failed belt happened as ppl where just starting the car or just setting off from a junction, Only seen one belt fail at high revs and it took 10 of the 16 valves and the head with it.
Right now I use a good quality Powergrip belt as I change each year anyhow
If I was running an expensive modded engine tho, I would buy the best belt I could find
Mark
Marky_GTSt is offline   Reply With Quote
