Boling water in hose Pump -> Radiator *HELP*
Hi,
I just bought my mint con. Nissan skyline R32 GT-R -93 with 7890Km. After driving it with no problems at all i opened the hood and checked everyting after a long motorway run. And i felt on the hose between the radiator and waterpump. It felt like the water was boiling. Talk about Fear. I remember the guy i bought it from talked about air in the watersystem because he had run with low, not empty, but low waterlevel in the "waterholder"When i open the cap there isnt any pressure. No Phhyyy. And there arnt any bubbles either. But shouldnt there be a pressure? The car runs great. The water temrature is stable in the middle of the scale. It has a stable idle at around 900RPM. What ca be wrong? Head gasket? Waterpumps dead? Pleas help!! ![]() |
Could just be an air lock. Theres a screw on the Balance pipe, near the injectors. If you remove this ENGINE COLD!!!, you should get rid of the trapped air.
Regards
Nigel...........GTROC Member Now on '32GTR No.3 |
Check the rad expansion tank for oil and the oil cap thingy for mayo. If none then it may well be an airlockas most people suspect in this case. But IMHO I'd put money on a cracked head, especially of it been run with a low coolant level and air in the system as the coolant will have just boiled where it was rather than being pumped around, and the air pockets will have become superheated.
Check the rad top pipe - there is a kink in it where air will collect and effectively boil through the rubber of the hose... |
There is no kink/mayo in the oil cap. And there is no oil in the water. The motor runs fine and there is no other signs of problem. So i hope there is a airlock in the system that hasnt ruined the cylinder head.
But why is there no pressure when i release the cap on the water holder? Last edited by humanizer; 17th July 2005 at 04:10 PM. |
After reading this thread I thought I'd have a look around the engine to find this bleed nut because I'd never heard of it (
) and found it, although there appears to be two nuts there - one with an allen key hole, and a regular nut.Which one do you undo to release trapped air? EDIT: Found out (thanks Gary) its the hexagonal bolt (one that faces the wing) Last edited by Durzel; 18th July 2005 at 12:02 PM. |
Now I have tried to change the water. Ive done everything as the manual say. When I run at idle til the watertemp goes to the middle i stop the car and feel the hoses. The upper hose (where it boiled before) is really warm. The hose down under is ice cold. The top of the radiator is warm. The rest is cold. Why!! The water dont seem to circulate. Can it be the waterpump? och the thermostat? What can be wrong? And where do I order parts? I live in sweden. But UK should be ok.
I cant get no warmth of the heatersystem either. Please help |
Hello mate,
It sounds very much like a thermostat issue, or quite possibly a blocked radiator. The water is pumped around the engine and out through the top hose, and back into the block through the bottom hose. Did you remove the Air bleed screw when you filled it? I think I would first remove both hoses from the Rad, and see if it flows properly. Then I'd remove the Thermostat and check it, in a saucepan with a thermometer. I once had a similar problem on a Porsche 944, it turned out to be the thermostat. You can get a Nismo thermostat on E-bay, from the USA. I'd seriously run the car for a few hours with no thermostat fitted though, just to see if she runs ok, or still gets hot. You will find that the engine will warm up fine round town, but will get cooler if you go on the freeway. Hope this helps Regards
Thanks! I did release the bleed screw when I filled her up. I will try to removet the thermostat. The strangest thing about all this, is that i get a stable watertemp on the gauge. But obviously not in the engine.
Regards Johnny |
#12 (permalink) | |
Regards
#14 (permalink) |
I have driven her for a testrun. But without thermostat. But the water still boils in the hose. And a little in the radiator too, i think. not in the engine tho. COuld it be the waterpump? I will check it monday. Otherwise I rip apart the engine. change the headgasket and pressurize the head and look for cracks.
Wouldnt it be smartest to lift the head with turbos and intake on it? Less gaskets to change. And less work? And is it possable to go that way? |
#15 (permalink) |
I'd check the rad cap, had something similar to this on another car and it turned out the rad cap was releasing pressure too soon so the system couldn't presurise, which lowers the boiling point. Changed the cap and all is fine now.
Keith |
