Old 22nd July 2005, 04:50 PM   #1 (permalink)
winegtr's Avatar
gearbox removel
Hi All
Just,t taken the gearbox out of the car r 33 gtr not to bad a job BUT
there was not anuff gearbox movement "backwards" so had to take the clutch off flywheel etc as the bellhousing wld not clear the clutch
so im thinking when i bolt on the new clutch and try to refit the gearbox theres not anuff movement backward to slide it all back together
Is this normal or do i have to tilt the engine ???? or is it just me
Hope this makes sence
Stu
winegtr is offline   Reply With Quote
Old 22nd July 2005, 09:08 PM   #2 (permalink)
Peter's Avatar
Looking from the rear to the front, you need to rotate the box about 70 degs clockwise to remove it whole...
Old 22nd July 2005, 11:33 PM   #3 (permalink)
cokey's Avatar
When I read that.....
I heard the voice of Yoda !
Too late I trashed 2 Ginken clutch plates
Be Gentle with the force !
cokey
Old 23rd July 2005, 12:43 AM   #4 (permalink)
Peter's Avatar
Old 23rd July 2005, 08:26 AM   #5 (permalink)
winegtr's Avatar
Cheers folks
Think i mite put the old clutch back on then have some test runs refitting it
Stu
Old 23rd July 2005, 10:07 AM   #6 (permalink)
NITO's Avatar
To make it easier going back in, jack the engine up from the front pulley, using a block of wood between the pulley and the jack, I jacked mine up until the fan was touching the shroud, you need to slip the gearbox in at the same angle as the engine. When you remove it the engine moves with the weight of the box. Going back in is a different story, I also used some grease on the input shaft to ease it in.
Regards
Nito
Old 23rd July 2005, 11:12 AM   #7 (permalink)
NISFAN's Avatar
cokey
PMSL
What the hell did you use to persuade the gearbox to slide in..........a lump hammer?
Old 23rd July 2005, 11:55 AM   #8 (permalink)
cokey's Avatar
I used two Idiots
Bad call
cokey
Old 23rd July 2005, 12:00 PM   #9 (permalink)
NITO's Avatar
lol, I tried that first too,
then I bought a transmission jack, much easier and safer! Especially with the 6 speed box!
Old 23rd July 2005, 03:24 PM   #10 (permalink)
winegtr's Avatar
I used two Idiots
Bad call
cokey
Ive only got the help of One Idiot and a fool
Stu
