Old 27th July 2005, 03:36 PM   #1 (permalink)
Maxi's Avatar
Gearbox shaking
Hi
I noticed that the gear lever of my R34 GTR gearbox will shake sometimes when starting, especially when doing a lot of slow starts in traffic and hot weather.
I have an ATS twin carbon clutch fitted, and of course probably when the carbon is starting to be warmer it sticks more and could cause some vibrations, but I also have fitted some new nismo engine and gearbox mounts.
Sometimes after a lot of traffic driving, if you start uphill the gearlever really shakes a lot, and I also noticed that when you accelerate hard on the wet and the rear wheels are spinning a little, there is some shaking of the gear lever.
Is there any other gearbox mount to check?
Thanks
Maxi is offline   Reply With Quote
Old 28th July 2005, 08:11 AM   #2 (permalink)
Maxi's Avatar
BTTT
Old 28th July 2005, 08:14 AM   #3 (permalink)
POssible Nismo gearbox mount?
Jay-Kay is offline   Reply With Quote
Old 29th July 2005, 04:28 PM   #4 (permalink)
Contact ATS with the problem and post what they say.
GL.
Phoenix_Master is offline   Reply With Quote
Old 6th August 2005, 10:05 PM   #5 (permalink)
Maxi's Avatar
It will do it also sometimes if you do a fast start.
Old 7th August 2005, 01:43 PM   #6 (permalink)
DCD
DCD's Avatar
Send a message via MSN to DCD
It happens because you don't give it enough revs maxi Try 7000 next time
Old 14th September 2005, 01:44 AM   #7 (permalink)
Maxi's Avatar
I think it does it because the clutch is not smoothly warmed up, but what I don't know is why the gearbox is shaking, it should be better as I have the nismo silent blocs fitted.
Do you think it would help to change the cross member bushes for polyurethane ones or metal ones?
Old 30th September 2005, 12:57 PM   #8 (permalink)
Maxi's Avatar
BTTT
