LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 30th July 2005, 12:15 AM   #1 (permalink)
Unhappy Low oil pressure (I think)
My R32 seems to suddenly have very low oil pressure. The needle is actually on 0 at startup but the warning light is not on. If i blip the throttle it doesn't really move .... then suddenly it jumps up to 2 where it will then happily sit a idle and where it stays regardless of what revs the car is doing. Now if I’m to believe what the gauge is telling me I’m fairly sure i should be very worried.
There are two things that make me think that the gauge may be telling porkies:
1: Having just fitted Apexi power intake induction kit I’m wondering if i have got a dodgy connection to the sensor which i have disturbed somehow???
2: The other possibility is that another problem i have at the moment with a dodgy alternator which is causing me to have really dim lights when i first start the car, is somehow effecting the power supply to the gauge. Is that a possibility or is that just wishful thinking on my part?
How reliable are the standard oil pressure gauges in an R32?
Any ideas on things I can eliminate before panicking more than i am now and resigning myself to a possibly large bill??
BLZBUBB is offline   Reply With Quote
Old 30th July 2005, 12:56 AM   #2 (permalink)
Peter's Avatar
More than likely the oil pressure sender is faulty. There are 10 zillion threads about this known weakness on here, hit the search button mate...
Old 30th July 2005, 09:51 AM   #3 (permalink)
Daz
Daz's Avatar
Send a message via MSN to Daz
BLZBUBB - probably a faulty Oil Pressure Sender Unit and / or a faulty gauge.
I had my sender unit changed while my car was in having the turbo's done. I think my gauge is also faulty (going off what it displays anyway).
If you are worried about it, take it to a specialist and ask them to check it out.
Daz is offline   Reply With Quote
Old 30th July 2005, 11:00 AM   #4 (permalink)
Thumbs up
Cheers guys.
I did do a search but this is one of those things where I see a possibly large bill heading my way so thought it was best to ask
I'm just about to order some Defi gauges including a Oil pressure gauge... do these come with a sender?
Old 30th July 2005, 12:54 PM   #5 (permalink)
vennuth's Avatar
Send a message via MSN to vennuth
Mine had exactly the same symptoms and the sender was broken... along with the oil pump, resulting in a full bottom end rebuild. Be very gentle (or preferably don't drive it at all) untill you know what pressure it's making. Good luck, fingers crossed it's just the sender.
vennuth is offline   Reply With Quote
Old 30th July 2005, 02:46 PM   #6 (permalink)
Unhappy
Ok thats a little worrying!
I have just started it up and have been trying to diagnose the problem.
When it first started the pressure went straight up to just below 6. I let the car run and as the water temperature reached its normal place the pressure was around 4. I left it running to see what effect the oil temperature would have. As the oil temp got to 75-80ish (which is about as high as it will go without driving it) the pressure read around 2 until I blipped the throttle and it dropped to just between 0 and 2! I turned the car off and let it sit for a minute then turned it on again. This time the reading was 0! until i blipped the throttle again and the alternator kicked in and it went up slightly to about 1/4 of the way between 0 and 2.
Now assuming for the moment that the gauge is ok, to me this would point to a knackered pump
Old 30th July 2005, 03:05 PM   #7 (permalink)
stealth's Avatar
Location: somewhere over the rainbow ( not far from Jeff )
A mate of mines GTR 33 had this problem a few months back ,changed the pump as it was bugg*rd and then changed the bottom end shells as a precaution .The shells were just showing a slight sign of wear and cost about 90 quid ,he did it himself as he is a Mechanic ,all has been fine since
stealth is offline   Reply With Quote
Old 30th July 2005, 04:03 PM   #8 (permalink)
vennuth's Avatar
I'm not entirely sure - if it does read 6 bar from cold at some point then then pump can't be completely shot... mine only ever went to 2 bar max after I had the sender changed.
Stealth - my shells were completely and utterly worn... i.e. down to the copper
Old 30th July 2005, 04:14 PM   #9 (permalink)
Pikey's Avatar
That sounds like a knackered sender / wiring / gauge to me
Get a garage to remove the oil pressure switch and replace it with a proper mechanical oil pressure gauge. Then you really will know what's what.
Its no more than about 15 minutes work, so shouldnt cost you a packet.
Old 30th July 2005, 04:16 PM   #10 (permalink)
vennuth's Avatar
Good advice.
How's your car going?
Old 30th July 2005, 04:53 PM   #11 (permalink)
Cheers guys. I'm going to try and get a mechanical gauge on it and see what’s going on. Is the another more accessible point where i can get a reading from? If I’m reading the engine manual correctly the pressure switch is right down by the filter which will be a pain to get to. Again thanks for the help.
Old 30th July 2005, 05:04 PM   #12 (permalink)
Pikey's Avatar
It really isnt that bad, nowhere near as bad as getting to the filter. Its a big gold cylinder thing. 17mm thread IIRC
vennuth - car isnt going anywhere for the moment, just up on ramps while we sort this damn gearbox mount out. It should be ready to roll sometime next week
Old 30th July 2005, 05:52 PM   #13 (permalink)
vennuth's Avatar
Bet you can't wait
Old 30th July 2005, 08:45 PM   #14 (permalink)
Hmm I cant even get my hand to it? I'm going to try and get my hands on a gauge tomorrow and give it a go. The problem is it's my daily driver so I really need it. If I manage to get the pressure test done and it does show a knackered pump I cant really drive it to a garage.
Anyone know what pressure levels i should be expecting cold and warm??? (assuming i manage to get a gauge and manage to actually dislocate all my fingers and get to the pressure switch).
Old 31st July 2005, 10:54 AM   #15 (permalink)
vennuth's Avatar
Starting from cold you should see at least 5 bar at idle, preferably close on 6 - once warm you should see over 4 bar on boost past ~4k rpm.
