Back Pressure VS Boost
Can someone explain a little.. on why less back pressure will casue higher in boost??
e,.g. decatted run higher boost than usual... Larger bore runs higher boost.. etc... Thanks |
#4 (permalink) | |
You need a pressure differential before and after the turbine, and good flow. hence de catting and none retrictive exhaust raises boost. HOWEVER, a lot of modern engines rely on exhaust restriction to help control boost, as the wastegate port area and flow becomes inadequate with a very none restrictive post turbine system. Jap spec Supra twin turbos are like that, for example.
