Old 31st July 2005, 10:17 PM   #1 (permalink)
Alex j B's Avatar
Oil cooler - effect on oil pressure?
Speaking to a mate on saturday about fitting oil coolers, he seems to think that fitting an oil cooler will lower the oil pressure, as it has more space to pump the oil round?
Is this true, as I know the oil pumps aren't that great at the best of times.
Alex B
Old 31st July 2005, 11:00 PM   #2 (permalink)
NigelR32's Avatar
I personally dont agree with that theory.
What he forgot to say though, is that the cooler the oil, the higher the pressure.
Regards
Nigel...........GTROC Member
Now on '32GTR No.3
NigelR32 is offline   Reply With Quote
Old 1st August 2005, 07:40 AM   #3 (permalink)
Dave_R1001's Avatar
Would you not just add a bit more oil to the system when fitting a cooler?
Dave_R1001 is offline   Reply With Quote
Old 1st August 2005, 11:45 AM   #4 (permalink)
lightspeed's Avatar
No it won't.
The pressure is set by the clearances at the bearings.
Worn bearings = low pressure.
Fitting the cooler will reduce the pressure at the bearings only if it extremely restrictive hoses, fiitings and matrix were used.
Old 1st August 2005, 11:53 AM   #5 (permalink)
Alex j B's Avatar
Also, does it matter what size the cooler is, as I've found the ideal cooler, (for my use), but not sure if they need to be a specific size? (sorry if its a dumb question, but I don't want to break anything!)
Alex B
Old 1st August 2005, 02:30 PM   #6 (permalink)
rasonline's Avatar
aBOUT Alexjb comment:
wouldn't have thought that adding more space to the system will reduce the oil pressure (keeping all other factors constant, such as temp, etc.)
I would imagine that the oil pump would just fill up the extra space first and then continue as normal.
I mean, if you take a hosepipe with water pumped in it, and now you extend the length of the hosepipe you do have more capacity. Fill in a little more water and it gets rid of the extra air that is all. Then once this is clear, it will build up pressure as normal.
Remember, this is assuming that all other factors are constant, and not taking into accont that the average oil temperature will now be lower and may impact oil pressure. My point being to demonstrate that simply increasing the space within which the oil is pumped shouldn't automatically reduce the oil pressure, as it operates within a closed system.
Somebody please correct me if i'm wrong?
rasonline is offline   Reply With Quote
Old 1st August 2005, 05:00 PM   #7 (permalink)
oilman's Avatar
It won't affect oil pressure however it should affect your choice of oil.
With a cooler you can use a thinner oil.
Simon
tel : 01209 215164
Old 2nd August 2005, 09:12 PM   #8 (permalink)
andy g's Avatar
sorry to hijack this thread, but i have just had a mocal oil cooler fitted to the engine, can i now use a 10w to 30w oil now as im currently using 15w 50w???? was using the latter as was worried about the oil temperature without the cooler.
cheers
andy g is offline   Reply With Quote
Old 2nd August 2005, 09:32 PM   #9 (permalink)
oilman's Avatar
I would recommend a 5w-40 as a good choice.
Simon
tel : 01209 215164
Old 3rd August 2005, 09:39 AM   #10 (permalink)
Most oil cooler pieworks are too small a bore. 5/8 inch minimum IMO. I see a lot of kits using 1/2 inch hose and forged fittings. Bad, again, IMO. A coller and hoses will reduce flow, and have a pressure drop, just like an intercooler. Properly sized hoses, matrix and fittings will minimize this.
