Old 1st August 2005, 07:33 PM   #1 (permalink)
bonez59's Avatar
fuel pressure?? help please
hello, ive just put a HKS fuel pressure reg on my r32 GTR, i am running a fuel pressure gauge in the car, but i havnt got a clue what pressure to have it set on when on idle, and any idea what it should go upto when on boost, im running 0.8bar on high, dont know if this makes a difference or not??? and what about the size of the vacume hose to the fuel reg? does this make a difference?? The only reason i dont know what the car ran on the std reg is cause it broke before i put the gauge in. Please help, many thanks Ian
NURBURGRING in 7,52s!!!!!!!
AEM
R32 GTR.
JE Pistons
T78
3 large fuel pumps should do the JOB
202.8mph on GPS good, melting piston at the same time not good
MARLON MOTORSPORT
bonez59 is offline   Reply With Quote
Old 1st August 2005, 08:02 PM   #2 (permalink)
Banned
GTR-Zilla's Avatar
3 bar is standard, with vacuum pipe removed at idle.. what ecu are you running?
GTR-Zilla is offline   Reply With Quote
Old 1st August 2005, 08:30 PM   #3 (permalink)
bonez59's Avatar
std ecu, std injectors, std turbos. Nice one, any thing else that i need to know??
AEM
R32 GTR.
JE Pistons
T78
MARLON MOTORSPORT
Old 1st August 2005, 08:36 PM   #4 (permalink)
Banned
GTR-Zilla's Avatar
set it to 3 bar with the vacume disconnected, thats 43 psi and the injectors should flow 444cc assuming they are in good cond.
Old 1st August 2005, 08:41 PM   #5 (permalink)
bonez59's Avatar
spot on, ill give it a try tomoro and see what happens, i did set it to 3.4bar but with the vac hope on, many thanks ian.
AEM
R32 GTR.
JE Pistons
T78
MARLON MOTORSPORT
