Old 2nd August 2005, 08:20 AM   #1 (permalink)
Clutch Problem
Hi All,
I've got a problem with my clutch that is really starting to annoy me
When I first got the car I was told it was a Nismo twin plate clutch.
The problem I've got is it's really snatchy. When you use it in reverse it's fine, no problems at all and really smooth. When I use it going forwards sometimes it's fine and other times it's really snatchy and I either stall the car or kangaroo down the road
It's not just me though Jay-R32 off here has got an OSGiken twin in his car and he's drove my car and thinks the same as me.
I'm getting to the point where I'm thinking of changing the clutch because it's taking a little bit of the pleasure away from driving the car
Anybody got any ideas of what the problem could be or worse still is the clutch supposed to be like that?
Thanks in advance
John
John Mc is offline   Reply With Quote
Old 2nd August 2005, 04:36 PM   #2 (permalink)
Thinking about again. The clutch isn't fine sometimes really it's always sh!t! It's more to do with how much time I've got to get the car moving. If I've got all the time in the world then it's fine and I can get it moving but slowly. When there are any cars approaching and I need to get moving is when I stall or kangaroo.
It feels as though there is about 3-5mm movement between off and on. Yet there is about 30mm of on/off transition when using it in reverse Making using it in reverse a pleasure and using it going forwards a nightmare
Any help would be really appreciated.
John
Old 2nd August 2005, 04:59 PM   #3 (permalink)
rb30 710bhp
rockabilly's Avatar
Send a message via Yahoo to rockabilly
hi john. cant really help on this ,only i have a nismo twin that hates going backwards but is superb when driving?. i wonder if the plates could go in back to front?. sorry for being no help on this ...bernie.
fancy the south of france.
http://st-tropez.mysite.orange.co.uk/
Old 2nd August 2005, 09:22 PM   #4 (permalink)
Thanks Mate any help is better than none I was wondering if you could get the plates the wrong way around somehow Maybe somebody more technical than me might be able to shed some light?
Thanks Bernie
John
Old 3rd August 2005, 01:00 AM   #5 (permalink)
maybe the thrust bearing is too big for the clutch diafragm?
silverzilla is offline   Reply With Quote
Old 3rd August 2005, 09:42 AM   #6 (permalink)
Luke Emmott's Avatar
Nismo Twin
My 32... erm, my OLD 32 came with a nismo twin in it. I hated it and hence changed it for the OS... nothing wrong with it as it was sold on, just nowhere near as good and a pain to use.
Luke
Luke Emmott is offline   Reply With Quote
Old 3rd August 2005, 12:57 PM   #7 (permalink)
SimonM's Avatar
The clutch always spins the same way, whether you're driving forwards or in reverse. So I doubt this could be the problem.
Simon.
SimonM is offline   Reply With Quote
Old 3rd August 2005, 01:40 PM   #8 (permalink)
Luke
Have you sold it then mate? Nice one
I was thinking was it just the clutch but someone has replied on the skylineowners forum saying it could possibly be that the plates are worn and need changing??
Old 3rd August 2005, 01:42 PM   #9 (permalink)
Simon.
I thought that but then why is it different in opposite directions?
Thanks for the info though.
John
Old 4th August 2005, 04:48 AM   #10 (permalink)
hi John, why dont u try some adjustment at the clutch paddle.. or check your clutch pump, sometime u need to upgrade your clutch pump to suits nismo twin plate..
nagasan is offline   Reply With Quote
Old 4th August 2005, 09:05 AM   #11 (permalink)
Alex j B's Avatar
Nope, mine is exactly the same, (ORC twin), changed from an Os Giken, which was real easy to use, with the ORC its nice in reverse, but really snatchy when going forwards, first of all I had a genuine Nissan thrust bearing which I thought could have been the problem, so changed it for an Os Giken one, made no difference.
I can't see how worn plates would make it more snatchy and I think the Nismo master cylinder, (I think it is), only helps give it a lighter pedal from what I've heard.
I think its just something you've got to live with or change the clutch, if you do I'd recommend Os Giken!
Alex B
Old 4th August 2005, 10:11 AM   #12 (permalink)
Is reverse gear a shorter ratio than 1st? If so you need less engine torque to get going and hence less slip time which leads to a subjective `better` feel in reverse than 1st?
Old 4th August 2005, 06:20 PM   #13 (permalink)
JAY-R32's Avatar
Me too
I understand what you mean , but having driven the car i can honestly say that its not a subtle difference , it's like two totally different clutches , similar to my OS giken twin when in reverse , and a a tenth of that progression when (trying to) pull away in first.
JAY-R32 is offline   Reply With Quote
Old 4th August 2005, 07:11 PM   #14 (permalink)
So it isn't just me then I was wondering if you were ever going to join in Jay
Maybe I will just live with it for a while longer and try some launches at Santa Pod to loosen it up a little
Old 4th August 2005, 08:36 PM   #15 (permalink)
Originally Posted by devilboy
hi
possible wear in the dog legs of the clutch
when driven hard wear occurs in the side walls of the clutch housing
the drive plates dont seperate together and it creates drag and snatching
in reverse you will find that their is little wear to the dog leg (windows)
so it feels normal.
hope this helps (can be repaired very cheaply)
regards mick
tel 01132 426359 (work) after 9am for more detail if required
Thanks for that mate, I might just give you a call tomorrow to see what you can do Probably too late to give you a call now
John
