Old 2nd August 2005, 07:24 PM   #1 (permalink)
paul cawson's Avatar
Oil surge?
If you look at the link below my engine after a track day this Sunday at Snetterton. I braked into a long sweeping bend then as I accelerated you could hear a loud whine like you get when a pump is pumping air then a big end knock. Has anyone else seen a engine that has failed due to oil surge, did it look like this the centre main bearing has broken up and one of the big end bearings is now stuck to what was a new crankshaft.
http://uk.pg.photos.yahoo.com/ph/pau...bum?.dir=/f9af
Old 2nd August 2005, 08:32 PM   #2 (permalink)
lightspeed's Avatar
Ouch.
Not done this myself but I would expect that sort of thing to happen.
Did the sump have any extra baffles?
Where you running extra sticky rubber?
Was the oil full on the dip stick?
I'm about to start putting my motor back together soon - I don't like the trust sump with it's low ground clearance so I've picked up a Nismo sump baffle. not sure if that will be enough yet.
Good luck with the rebuild and commiserations.
Old 2nd August 2005, 09:13 PM   #3 (permalink)
360/PS3: TrevSkyline
Trev's Avatar
I would fit a Trust weld on sump extension (with extra baffles) which eliminates oil surge. Oil surge is a problem on heavy track/drag use and is a killer on the GTR engine.
12.7 @ 116 mph, Santa Pod May 2005
Old 2nd August 2005, 10:35 PM   #4 (permalink)
Yes will go for the extension, its strange to me that the centre bearing gave out you would have thought the last to get oil would go, or if the bearing was wiped out by crankshaft wobble due to excessive power one of the end ones.
Old 2nd August 2005, 10:40 PM   #5 (permalink)
Originally Posted by lightspeed
Ouch.
Oil level was on the full mark,no extra baffles,if you have more baffles and a good oil pump does the oil take longer to get back in the sump? normal road tyres but lowered and uprated shock absorbers, the only cars faster around the bends were the open top two seaters.
Old 2nd August 2005, 10:57 PM   #6 (permalink)
davewilkins's Avatar
I always fill my oil to the next mark above the max mark ( an H I think). Along with a Tomei baffled sump I have been ok so far.
Website of Dave Wilkins
davewilkins is offline   Reply With Quote
Old 3rd August 2005, 05:46 AM   #7 (permalink)
lightspeed's Avatar
A well designed baffle shouldn't make the oil take any longer to get to the sump.
It just stops the oil sloshing away from the pickup under high g loads.
The Nismo one uses guide plates and swinging trap doors to hold the oil around the pick up.
Tomei is similar but uses rubber flaps instead of metal doors.
Old 3rd August 2005, 07:26 AM   #8 (permalink)
If its got trap doors it should be fine, I like fitting Nismo parts if Nissan have designed something to stop surge it shows that there is a need for it.
Old 3rd August 2005, 09:36 AM   #9 (permalink)
hard to be 100% sure, but does look like oil starvation, yes. I always was OK when i ran an R33 GTR on track days with stock bottom end. No extra baffles, i h=just ran a 40 row oil cooler and an extar 1.5 litres of oil in the sump, checked EVERY session. Car ran on road legal race tyres on Ohlins with proper camber to make the tyres work. I race F3 and GT at National level, so I pushed the old girl as hard as it would go, for many many track days. Never an oiling problem. I used Motul race oil.
Old 3rd August 2005, 12:30 PM   #10 (permalink)
Chris - did you have a restrictor in the feed to the head?
Old 3rd August 2005, 01:57 PM   #11 (permalink)
No, the head had never been off.
Old 3rd August 2005, 05:33 PM   #12 (permalink)
Thanks. Also R33GTR with numerous track days with no probs, but still running road tyres.
Old 3rd August 2005, 09:31 PM   #13 (permalink)
The crankshaft counter weight has also been hitting on the underside of one of the forged piston small end pin bosses it was the one the shell had failed on, but it shows how close it all runs, I can see why a full counter crank is used now. the forged pistons also have shorter skirts, would have made a real mess of a standard piston.
I had a head oil flow restrictor fitted
Old 6th August 2005, 03:07 PM   #14 (permalink)
Piston had hit the cylinder head bent the connecting rod, then hit the crankshaft. Now that makes more sense
Old 6th August 2005, 03:13 PM   #15 (permalink)
Abbey M/S's Avatar
they never hit unless the big end has gone this makes another 1.0 +/-mm of free play.
This is why the piston has hit the head and the pistons has touched the crank.
Cant believe the con rod is bent , it may be fcuked with the bearing being spun but not bent.
As chris has said always overfill the motor with oil on the track , but if you had a DEFI oil pressure guage with playback you would have lost oil pressure around right hand corners.....
