Old 7th August 2005, 09:24 AM   #1 (permalink)
Banned
GTR-Zilla's Avatar
diff/ gearbox oil coolers
I know that from previous look up on the forum the pump is sold by nissan and is stupidly priced..
can an alternative pump bu used? ie
any tips from anyone who has dont the job?
GTR-Zilla is offline   Reply With Quote
Old 7th August 2005, 09:38 AM   #2 (permalink)
lightspeed's Avatar
The pumps are also fitted to some 200sx's and 300ZX's so might be worth calling a few breakers.
Old 7th August 2005, 05:15 PM   #3 (permalink)
Banned
GTR-Zilla's Avatar
so these mocal pumps are not suitable?
Old 7th August 2005, 09:57 PM   #4 (permalink)
NikWilson's Avatar
You need to be able to pump at the correct rate. I looked at these pumps and they were (in my opinion) not stong enough. I have 3 of the Nissan (Hitachi piston type) pumps left over from my project - brand new. These Nissan pumps were used on the 300ZX rear axel and R32. They originally retailed for £600 +Vat and were the ones used by Middlehurst on the R34 mods.
If you want any info on fitting coolers, look at my previous threads earlier this year.
It took me a lot of time and effort to get the set up right and I used 2 pumps to cool the getrag and transfer boxes. The electrics ended up being a bit of a head ache, but in the end worked out how to do it so that they only work with the engine running and when the boxes get to a 80' (make sure you do not use the pump to move cold oil!)
I did not bother with the rear diff' as on the R34 GTR v-spec, the rear diff has cooling fins anyway.
My wifes 1.1993 S13 200SX 1.8 Turbo has a rear diff cooler and pump (not the same pump as above), so see if you can get one off a scrapped car. Not sure if it will do the job, but works well on her S13.
Nik
NikWilson is offline   Reply With Quote
Old 7th August 2005, 10:52 PM   #5 (permalink)
Banned
GTR-Zilla's Avatar
Nick was reading some of your posts, wernt you selling the kits? id need one for the diff, gearbox and transfer box. as im turning my car into a track car. im not paying 600+vat for these pumps, sx second hand ones aside, whatr other pumps will do the job? im suprised the mocal ones are not good enough?
Old 8th August 2005, 08:50 AM   #6 (permalink)
Jabsco make a suitable nitrile impeller pump, the Mocal ones I have used on loads of different transaxles on race cars, too. Or Niks set up should be fine of course. The Jabsco ones tolerate some trash going through them, the Mocal ones need a filter screen in the input 9suction) line.
Old 8th August 2005, 10:41 AM   #7 (permalink)
NikWilson's Avatar
I am not saying that the Mocal pumps are not good enough, but the Hitachi ones are as used by Nismo on their coolers as well (as on the the Z-Tune). The cost of the pumps at £600.00 is stupidly high, I did not pay that for the pumps I bought, but then I did buy quite alot and now just have the 3 left over (brand new and boxed). What about a scrapped 300ZX and take the pump off a rear axel?
I did have one of the mocal pumps as you show in your post, but are in no way as good quality or as robust as the Hitachi ones. The flow rate is not so good either. I felt it was false economy to use the Mocal pumps, but this was just my opinion when comparing the 2 makes side by side.
Also, I was not selling the kits, all I did was to recommend the garage wher the tests and design were done with myslef over winter last year. They sell the kits and can if needed fit them.
I have all the designs etc and the way to wire up the pumps via the alternator and bore size of the braided hose I used. Also the way the rad's are mounted is crutial. Mine are bolted to a plate, wheich in turn is bolted to the underside of the spare wheel well.
Hope this helps, if you do want to buy the 3 new pumps, let me know. I was not posting as a sales pitch by the way!!!!!!!
cheers
Nik W
