Old 16th August 2005, 03:11 AM   #1 (permalink)
anyone no of how to change feul pump in r33gtr
does anybody no of how to change a feul pump on a r33 gtr and how much of a big job is it cheers
harry2 is offline   Reply With Quote
Old 16th August 2005, 06:44 AM   #2 (permalink)
Hi,
I changed mine a few years ago, wasn't particularly hard just a bit stinky as you end up having to put your arm into the petrol tank
Just remove the large black metal plate at the back of the boot which is with the strut brace. Then on the right you'll see the metal cover which is over the fuel tank, once this is removed you will have access to the top of the tank where the fuel pump is located. Sorry I can't give you exact details it was over 4 years ago I changed mine but it shouldn't be too hard just make sure you've already disconnected the battery before you start.
Mike
MikeR33 is offline   Reply With Quote
Old 16th August 2005, 04:05 PM   #3 (permalink)
Ajax's Avatar
I done mine at the weekend, as Mike has already said applies.
Unscrew the big black plastic ring on the top of the tank and all will be revealed. The pump is attached to a metal carrier and is simply slotted onto a bracket fitted to the tank, lift it all out together after pulling all the plugs off. Theres a rubber sleeve around the pump and you'l probebly have to re-use it for the new pump. This was abit of a bastid to get the pump out of, i used a couple of screwdrivers and washing up liquid and eventualy levered it out.
After the new ones fitted, make sure all the pipes are secured tight and make sure you'v got the polarity of the pump the right way round or it will pump in reverse.
Carefully refit the plastic lid on the tank as its easily cross threaded then fefit the 3 fuel lines, job done.
Ajax is offline   Reply With Quote
