Speed Wobble
I've got a GTR33 V-spec and when i was on my way home last night on a dry,straight,smoothish road I got a few wobbles from the back-end.What's causing this,I've recently had the battery changed.
ADMINISTRATOR
as i understand this is called "hicas Wobble"
can be problematic if the front wheels were not dead stright when you disconnected the battery AFAIK mook
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
Like Mookistar said.
I changed my battery and had the same problem. Dis-connect the battery and leave overnight, then make sure the wheels are straight and re-connect. If this don't work might be worth having the alignment checked. On another not where in Somerset are you from??? |
#5 (permalink) | |
Yeovil |
Have you got some bass in the boot???
Search on here as there have been many posts about it More likely the cause,if the wheels were not straight when the batt got connected you would notice it all the time. |
Does the battery have to be disconnected for a long period such as overnight like Kenan suggested for it to work or can it be left for an hour so? Just asking as I'm pretty positive I'm getting the "Hicas wiggle" (I say wiggle because it doesn't seem as drastic a full on wobble) at highish speeds.
did you have your ICE playing at the time
the magnetic field of the speaker magnet will affect the hicas ecu at certain hertz ![]()
The GTR Shop - Skyline GTR Breaker and Parts supplier. We buy your crash damaged, broken or mot failed car for cash. call now. For all your GTR needs. From 1/2 clips to turbos, seats to shells , harness's to engines. call Mobile 07731304953 GTR店 We ship worldwide.
